Click to visit BT.com
BT.com
Wishlist
Olympus DP-20 Digital Notecord
Quicklinx: 794NWS00
Mfr#: N2285921
The DP-20 is specially designed to be even simpler to use than a tape-based device. Fans of analog recorders will find the DP-20 has everything they love about their old tape-based voice recorder: a full-sized speaker for clear audio playback, three big buttons for the basic functions, an easy-to-read display and excellent battery life. Olympus' calendar search system, makes finding sound files just as intuitive as with analog tape. From notes-to-self to a child's recital, this groundbreaking model makes recording and reviewing easier than ever before.
  • Easy to use
    As you'd expect of an Olympus digital voice recorder, the WMA format ensures sound quality on the DP-20 is far superior to a typical analog device. But for people used to recording on cassettes, the exciting factor is the familiar design - they intuitively know how the DP-20 works. Instead of the five- or six-button arrangement on a standard digital recorder, the front panel on the DP-20 features the same three large buttons that make an analog recorder so easy to use.
  • Easy to search
    On an old cassette-based voice recorder, when users wanted to find a specific recording, they had to read the index card and check through a window how far the tape had moved. With the DP-20, managing and searching for digital files or folders is much simpler than that. Instead of navigating endless folder levels as you do on a computer, users can store files by date and find them again in three short steps - using the unique calendar search feature.
  • Easy to read
    The DP-20's 1.78-inch LCD likewise makes it easier to archive and pick out files. The LCD is much larger and clearer than usual in this price category and the full-dot display is another rare luxury. Together with the uncluttered layout, it makes for superb legibility. Digital devices often use small segment lettering, which makes it difficult to pick out vital information like the battery and capacity status. But the big DP-20 display leaves plenty of space for extra-large font size, big icons and clear status bars. So whether users are busy with children or concentrating on a class, a quick glance at the screen is all that's required.
  • Easy all-round
    From recording to playback and archiving to erasing, the DP-20 is a pleasure to use. In combination with Olympus' trademark audio quality, the extra-large speaker plays back files with expansive, natural sound. The tone is consistent, no matter which playback speed you choose. When users record, they have an uncomplicated choice of settings: noise cancellation on or off, microphone sensitivity high or low, audio quality high or standard. Whichever setting they choose, the DP-20 captures crystal-clear audio, from school plays to kitchen table chat. It's an impressive showing for this great-value alternative to over-complex digital devices - and out-of-date analog voice recording.
Olympus DP-20 - voice recorder
Voice recorder flash based
Enclosure Colour
Silver
5 cm x 1.8 cm x 9.5 cm
78 g
Playback Digital Standards
WMA
Digital Recording Time
67 hours - HQ (High Quality), 131 hours - SP (Standard Play)
Built-in Display
Monochrome 1.78 in - LCD
Audio Specifications
Digital Player - Response Bandwidth - 70 - 13000 Hz
Flash Memory
1 GB
Speakers
1 x speaker - built-in
Microphone
1 x microphone - built-in - mono
2 x battery - AAA type - Alkaline
Voice recorder
Digital Player Type
Flash based
5 cm
1.8 cm
9.5 cm
78 g
Enclosure Colour
Silver
Supported Digital Audio Standards
WMA
Audio System
Flash Memory
1 GB
Hold button, playback speed control, noise cancelling circuit, calendar, LCD display, built-in speaker
Built-in Display
Built-in Display
LCD - monochrome
Diagonal Size
1.78 in
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish
Speaker System
Speakers
Driver Details
Speaker : 1 - 1.42"
Digital Player (Recorder)
Edit Functions
Erase
Recording Time
Supported Bit Rate
16/32Kbps
Sample Rate
22 kHz, 44.1 kHz
Microphone
Microphone - built-in
Microphone Operation Mode
Mono
Included Qty
1
Connector Type
Headphones ( mini-phone 3.5mm )
Included Qty
2
Battery Life Details
Digital recording - Alkaline - up to 63 hour(s) , Digital playback - Alkaline - up to 69 hour(s)
