BT.com
Wishlist
Olympus DM-901 Pro Digital Voice Recorder
Olympus DM-901 Pro Digital Voice...
£119.02
17 in stock
£119.02
Add to wishlist
Delivery
Standard 1-3 working days
The DM-901 unites premium sound quality with mobile features for easy note-taking in any situation. For the first time on an Olympus recorder, Wi-Fi links the DM-901 to a user's smartphone, from which an available app can remotely trigger the DM-901 to record on command. This feature is ideal for capturing events when there is a significant distance between the user and the speaker.
Olympus DM-901 - voice recorder - flash memory card
Voice recorder flash based
Media Content Source
Flash memory card
5.1 cm x 1.8 cm x 11.4 cm
105 g
Playback Digital Standards
WMA, PCM, MP3
Built-in Display
Colour 2 in
Supported Flash Memory Cards
SDHC, SD Memory Card, SDXC
Flash Memory
4 GB
Interface Supported
USB 2.0, Wi-Fi
Digital voice recorder battery rechargeable - Lithium Ion
Voice recorder
Digital Player Type
Flash based
USB Specification Version and Speeds
USB 2.0
5.1 cm
1.8 cm
11.4 cm
105 g
Interface Supported
USB 2.0, Wi-Fi
Supported Digital Audio Standards
WMA, PCM, MP3
Audio System
Flash Memory
4 GB
Noise cancelling circuit, low-cut filter, Voice Guidance
Built-in Display
Built-in Display
Display Illumination
Diagonal Size
2 in
Digital Player (Recorder)
Supported Bit Rate
8 - 320Kbps (MP3) / 5 - 320Kbps (WMA)
Connector Type
USB 2.0
USB cable
Software
Olympus Sonority
Power adapter - external
Battery Life Details
Voice recording - up to 850 hour(s)
Scroll to top
