BT.com
Wishlist
OKI Microline 5790eco Mono Dot-Matrix Printer
OKI Microline 5790eco Mono...
£453.09
Hurry, only 1 left in stock!
£453.09
Add to wishlist
Delivery
Standard 1-3 working days
The ultra reliable ML5790eco dot matrix printer delivers fast, high quality printing of multi-part forms, truly versatile paper handling and impressively low energy consumption. Its high 576 characters per second (cps) print speed, fast throughput and ability to manage heavy medias make the ML5790eco perfect for high duty applications where presentation and print quality are essential. And with multiple emulations built-in, replacing old printers is simple and straightforward.
Ideal for printing customer facing documents such as receipts, invoices, dispatch notes and spreadsheets, on single or multipart paper, the ML5790eco will keep productivity levels high and document presentation professional.
OKI Microline 5790eco - printer - monochrome - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
7.5 kg
Max Media Size
Continuous paper 76.2 mm - 254 mm (width)
Min Media Size (Custom)
76.2 mm x 76.2 mm
Max Media Size (Custom)
254 mm x 558.8 mm
Print Speed
Up to 576 char/sec - high speed draft , Up to 480 char/sec - high speed draft , Up to 540 char/sec - draft , Up to 432 char/sec - draft , Up to 240 char/sec - letter , Up to 206 char/sec - letter , Up to 180 char/sec - letter , Up to 144 char/sec - letter , Up to 120 char/sec - letter , Up to 360 char/sec - draft , Up to 360 char/sec - draft , Up to 309 char/sec - draft
Max Resolution (B&W)
360 dpi
Parallel, USB
RAM Installed (Max)
128 KB
Language Simulation
EPSON ESC/P 2, IBM AGM, IBM PPR, EPSON LQ
Barcodes
Matrix 2 of 5, Industrial 2 of 5, Code 39, NW-7, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, OCR-A, OCR-B, Code 128B, Code 128C, Code 128A
Media Type
Envelopes, labels, plain paper, continuous forms, cards
AC 230V
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
3 years warranty with product registration
43.8 cm x 37.5 cm x 19.1 cm
Printer Type
Printer
Print Speed
Up to 576 char/sec - high speed draft - 12 cpi , Up to 480 char/sec - high speed draft - 10 cpi , Up to 540 char/sec - draft - 15 cpi , Up to 432 char/sec - draft - 12 cpi , Up to 240 char/sec - letter - 20 cpi , Up to 206 char/sec - letter - 17.1 cpi , Up to 180 char/sec - letter - 15 cpi , Up to 144 char/sec - letter - 12 cpi , Up to 120 char/sec - letter - 10 cpi , Up to 360 char/sec - draft - 10 cpi , Up to 360 char/sec - draft - 20 cpi , Up to 309 char/sec - draft - 17.1 cpi
Wired
Parallel, USB
360 dpi
Language Simulation
Fonts Included
1 x scalable , 1 x barcode
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Max Media Size
76.2 mm x 76.2 mm
254 mm x 558.8 mm
Media Sizes
Media Feeders
1 x manual - 1 sheet - continuous paper 76.2 mm - 254 mm (width)
Max Sheets in Multi-Part Form
6
1 x parallel , 1 x USB - 4 pin USB Type B
Consumables Included
1 x printhead - up to 400 million characters , 1 x ribbon - up to 8 million characters
MTBF
25,000 hour(s)
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
52 Watt
Power Consumption Stand by / Sleep
1.5 Watt
Software Included
OKI LPR, OKI Status Monitor, OKI Network Set Up
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
Sound Emission (Operating)
57 dBA
Sound Emission (Quiet Mode)
52 dBA
43.8 cm
37.5 cm
19.1 cm
7.5 kg
Scroll to top
