BT.com
Wishlist
OKI Microline 5590eco Mono Dot-Matrix Printer
OKI Microline 5590eco Mono...
£396.04
Hurry, only 3 left in stock!
£396.04
Add to wishlist
Delivery
Standard 1-3 working days
The Microline 5590 has been designed for use in the harshest of operating environments whilst offering the highest levels of flexibility and performance with unparalleled reliability.
The ML5590 carriage model features advanced specifications that ensure excellent productivity and reliability every time. Its robustness and flexibility make it the ideal choice for demanding environments. The 24-pin print head also provides a better print quality than 9-pin counter-parts for the printing of invoices, spreadsheets etc.
OKI Microline 5590eco - printer - monochrome - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
5.9 kg
Max Media Size
Continuous paper 76 mm - 254 mm (width)
Min Media Size (Custom)
76.2 mm
Max Media Size (Custom)
254 mm
Print Speed
Up to 473 char/sec - max speed , Up to 420 char/sec - high speed draft , Up to 378 char/sec - utility , Up to 315 char/sec - utility , Up to 105 char/sec - letter , Up to 126 char/sec - letter
Max Resolution (B&W)
360 dpi
Parallel, USB
RAM Installed (Max)
128 KB
Language Simulation
EPSON ESC/P 2, IBM AGM, EPSON LQ, IBM ProPrinter
Barcodes
Code 39, EAN/JAN-8 , EAN/JAN-13 , UPC-A, UPC-E, Interleaved 2 of 5, Postnet , OCR-A, OCR-B, Code 128B, Code 128C, Code 128A
Media Type
Envelopes, labels, plain paper, continuous forms
AC 230V
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
3 years warranty with product registration
39.8 cm x 34.5 cm x 12 cm
Printer Type
Printer
Print Speed
Up to 473 char/sec - max speed - 15 cpi , Up to 420 char/sec - high speed draft - 10 cpi , Up to 378 char/sec - utility - 12 cpi , Up to 315 char/sec - utility - 10 cpi , Up to 105 char/sec - letter - 10 cpi , Up to 126 char/sec - letter - 12 cpi
Wired
Parallel, USB
360 dpi
Language Simulation
Fonts Included
1 x scalable , 1 x barcode
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Path Type
Curved
Media Type
Max Media Size
76.2 mm
254 mm
Media Sizes
Envelope Sizes
US No 6 (92 x 165 mm)
Media Feeders
1 x manual - 1 sheet - continuous paper 76 mm - 254 mm (width)
Max Sheets in Multi-Part Form
5
1 x parallel - 36 PIN Centronics , 1 x USB - 4 PIN USB Type B
Consumables Included
1 x printhead - up to 200 million characters , 1 x ribbon - up to 4 million characters
MTBF
20,000 hour(s)
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
45.9 Watt
Power Consumption Stand by / Sleep
1.5 Watt
Environmental Standards
ENERGY STAR
Service & Support Details
Limited warranty - 3 years
Sound Emission (Operating)
56 dBA
Sound Emission (Quiet Mode)
52 dBA
39.8 cm
34.5 cm
12 cm
5.9 kg
Scroll to top
