BT.com
Wishlist
OKI Microline 5521eco Mono Dot-Matrix Printer
OKI Microline 5521eco Mono...
£460.54
£460.54
Add to wishlist
Delivery
Standard Due date unavailable
The Microline 5521 has been designed for use in the harshest of operating environments whilst offering the highest levels of flexibility and performance with unparalleled reliability.
OKI Microline 5521eco - printer - monochrome - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 9 pin - monochrome
7.7 kg
Max Media Size
Continuous paper 76 mm - 406 mm (width)
Min Media Size (Custom)
76 mm
Max Media Size (Custom)
406 mm
Print Speed
Up to 570 char/sec - super speed draft , Up to 507 char/sec - high speed draft , Up to 380 char/sec - utility , Up to 95 char/sec - near letter
Max Resolution (B&W)
240 x 216 dpi
Parallel, USB
RAM Installed (Max)
128 KB
Language Simulation
EPSON FX, Okidata Microline, IBM ProPrinter
Barcodes
OCR-B
Media Type
Envelopes, plain paper, continuous forms
AC 230V
3 years warranty with product registration
55.2 cm x 34.5 cm x 12 cm
Printer Type
Printer
Print Speed
Up to 570 char/sec - super speed draft - 12 cpi , Up to 507 char/sec - high speed draft - 10 cpi , Up to 380 char/sec - utility , Up to 95 char/sec - near letter
Wired
Parallel, USB
240 x 216 dpi
Language Simulation
Fonts Included
1 x scalable , 1 x barcode
Barcodes
OCR-B
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Max Media Size
76 mm
406 mm
Media Sizes
Envelope Sizes
Com-10 (105 x 241 mm)
Media Feeders
1 x manual - 1 sheet - continuous paper 76 mm - 406 mm (width)
Max Sheets in Multi-Part Form
6
1 x parallel - 36 PIN Centronics , 1 x USB - 4 PIN USB Type B
Consumables Included
1 x printhead - up to 200 million characters , 1 x ribbon - up to 4 million characters
MTBF
20,000 hour(s)
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
40.2 Watt
Power Consumption Stand by / Sleep
1.5 Watt
Environmental Standards
ENERGY STAR
Service & Support Details
Limited warranty - 3 years
Sound Emission (Operating)
56 dBA
Sound Emission (Quiet Mode)
52 dBA
55.2 cm
34.5 cm
12 cm
7.7 kg
Other bundles
£460.54
TP Link Smart Plug
Save £0.98
£485.53
Scroll to top
