BT.com
Wishlist
OKI Microline 5520eco Mono Dot-Matrix Printer
OKI Microline 5520eco Mono...
£383.67
14 in stock
£383.67
Add to wishlist
Delivery
Standard 1-3 working days
The ML5520eco printer is suited to high speed, high volume data and word processing applications where fast throughput and flexible paper management are required.
This 9-pin, narrow carriage, impact printer is engineered to be tough enough for dedicated printing in the most demanding environments. With outstanding reliability, ease-of-use and barcoding facilities and the ability to run twice as long as most printers in their class, they are ideal for supporting forms printing at customer service points in wholesale and service environments.
OKI Microline 5520eco - printer - monochrome - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 9 pin - monochrome
5.9 kg
Max Media Size
Continuous paper 76 mm - 254 mm (width)
Min Media Size (Custom)
76 mm
Max Media Size (Custom)
254 mm
Print Speed
Up to 570 char/sec - super speed draft , Up to 507 char/sec - high speed draft , Up to 380 char/sec - utility , Up to 95 char/sec - near letter
Max Resolution (B&W)
240 x 216 dpi
Parallel, USB
RAM Installed (Max)
128 KB
Language Simulation
EPSON FX, Okidata Microline, IBM ProPrinter
Barcodes
OCR-B
Media Type
Envelopes, plain paper, continuous forms
AC 230V
3 years warranty with product registration
39.8 cm x 34.5 cm x 12 cm
Printer Type
Printer
Print Speed
Up to 570 char/sec - super speed draft - 12 cpi , Up to 507 char/sec - high speed draft - 10 cpi , Up to 380 char/sec - utility , Up to 95 char/sec - near letter
Wired
Parallel, USB
240 x 216 dpi
Language Simulation
Fonts Included
1 x scalable , 1 x barcode
Barcodes
OCR-B
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Max Media Size
76 mm
254 mm
Media Sizes
Envelope Sizes
US No 6 (92 x 165 mm)
Media Feeders
1 x manual - 1 sheet - continuous paper 76 mm - 254 mm (width)
Max Sheets in Multi-Part Form
6
1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
Consumables Included
1 x printhead - up to 200 million characters , 1 x ribbon - up to 4 million characters
MTBF
20,000 hour(s)
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
40.2 Watt
Power Consumption Stand by / Sleep
1.5 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
Sound Emission (Operating)
56 dBA
Sound Emission (Quiet Mode)
52 dBA
39.8 cm
34.5 cm
12 cm
5.9 kg
Scroll to top
