BT.com
Wishlist
OKI Microline 4410 Mono Dot-Matrix Printer
OKI Microline 4410 Mono Dot-Matrix...
£2,075.14
Hurry, only 2 left in stock!
£2,075.14
Add to wishlist
Delivery
Standard 1-3 working days
OKI Microline 4410 is a dependable, day in/day out, heavy-duty, high-speed printer. The exceptional performance of the ML4410 is perfectly suited to applications requiring high volume including long, unattended print runs, general data processing, invoices, billing and financial statements, inventory reports, banking transaction logs and accounting reports.
For strength and stability, the ML4410 has a larger, beefier carriage assemble, ensuring optimal print quality. The metal chassis gives the printer greater rigidity and strength in rugged environments. Even the tear bar is long-lasting metal - for clean precise cutting.
OKI Microline 4410 - printer - monochrome - dot-matrix
Printer Type
Personal printer - dot-matrix - 18 pin - monochrome
42 kg
Max Media Size
Super A3/B (330 x 483 mm), Tabloid Extra (305 x 457 mm)
Max Media Size (Custom)
406 mm
Print Speed
Up to 800 char/sec - normal , Up to 1066 char/sec - max speed , Up to 200 char/sec - near letter
Max Resolution (B&W)
288 x 144 dpi
Parallel, serial
RAM Installed (Max)
512 KB
Flash Memory Installed (Max)
1 MB
Language Simulation
EPSON FX, IBM PPR, Okidata Microline
Media Type
Labels, plain paper, continuous forms, cards
AC 120/230 V
3 years warranty with product registration (Germany - 3 years (on-site) with product registration)
76.8 cm x 38.5 cm x 37.8 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
Parallel, serial
288 x 144 dpi
PostScript Support
Not available
Language Simulation
Fonts Included
8 x barcode , 2 x scalable
RAM
RAM Installed (Max)
512 KB
Flash Memory
Flash Memory
1 MB
Media Handling
Media Type
Max Media Size
406 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), Super A3/B (330 x 483 mm), A3 plus (329 x 423 mm), Roll (40.6 cm), Tabloid Extra (305 x 457 mm)
Max Sheets in Multi-Part Form
10
Duty Cycle
Cartridge / Printhead Duty Cycle
400 million characters
Expansion Slots
1 x expansion slot
1 x RS-232 - 25 pin D-Sub (DB-25) , 1 x parallel - 36 PIN Centronics
MTBF
12,000 hour(s)
Plug and Play, TUV
Power supply
AC 120/230 V
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 3 years - carry-in
5 °C
35 °C
20 - 80%
Sound Emission
52 dBA
76.8 cm
38.5 cm
37.8 cm
42 kg
Other bundles
£2,075.14
Save on TP Link Smart Plug
Save £2.00
£2,099.11
Scroll to top
