BT.com
Wishlist
OKI Microline 3390eco Mono Dot-Matrix Printer
OKI Microline 3390eco Mono...
£369.63
£369.63
Add to wishlist
Delivery
Standard Due date unavailable
The Microline 3390 narrow and wide carriage printer is designed for users who require excellent quality and flexibility from a single printer. The Microline 3390 is ideal for volume applications requiring high throughput and flexible changing between various print media. High reliability, ease of use and various in-built barcodes makes this printer the ideal tool for industrial, commercial, service, small business and office environments.
OKI Microline 3390eco - printer - monochrome - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
5.8 kg
Max Media Size
Continuous paper 76.2 mm - 254 mm (width)
Min Media Size (Custom)
76.2 mm
Max Media Size (Custom)
254 mm
Print Speed
Up to 390 char/sec - max speed , Up to 260 char/sec - utility , Up to 312 char/sec - utility , Up to 104 char/sec - letter , Up to 87 char/sec - letter
Max Resolution (B&W)
360 dpi
Parallel, USB
RAM Installed (Max)
128 KB
Language Simulation
IBM AGM, EPSON LQ, IBM ProPrinter
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, OCR-A, OCR-B, Code 128B, Code 128C, Code 128A
Media Type
Envelopes, labels, plain paper, continuous forms, cards
AC 230V
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
3 years warranty with product registration
39.8 cm x 34.5 cm x 11.6 cm
Printer Type
Printer
Print Speed
Up to 390 char/sec - max speed , Up to 260 char/sec - utility - 10 cpi , Up to 312 char/sec - utility - 12 cpi , Up to 104 char/sec - letter - 12 cpi , Up to 87 char/sec - letter - 10 cpi
Wired
Parallel, USB
360 dpi
Language Simulation
Fonts Included
1 x scalable , 1 x barcode
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Max Media Size
76.2 mm
254 mm
Media Sizes
Envelope Sizes
US No 6 (92 x 165 mm)
Media Feeders
1 x manual - 1 sheet - continuous paper 76.2 mm - 254 mm (width)
Max Sheets in Multi-Part Form
5
1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
Consumables Included
1 x printhead - up to 200 million characters , 1 x ribbon - up to 2 million characters
MTBF
10,000 hour(s)
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
30.4 Watt
Power Consumption Stand by / Sleep
1.5 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
Sound Emission (Operating)
57 dBA
Sound Emission (Quiet Mode)
52 dBA
39.8 cm
34.5 cm
11.6 cm
5.8 kg
Scroll to top
