BT.com
Wishlist
OKI Microline 3321eco Mono Dot-Matrix Printer
OKI Microline 3321eco Mono...
£422.11
£422.11
Add to wishlist
Delivery
Standard 1-3 working days
The ML3320eco and wide carriage ML3321eco printers are suited to high speed, high volume data and word processing applications, where fast throughput and flexible paper management are required. These 9-pin, impact printers are engineered to be tough enough for dedicated printing in the most demanding environments. With outstanding reliability, ease-of-use and barcoding facilities as well as the ability to run twice as long as most printers in their class, they are ideal for customer service points in wholesale and service environments.
The ML3320eco/ML3321eco can accommodate multipart forms and stock that are up to twice as thick as those that fit OKI's nearest competitor. Their relentless performance comes from OKI's unique, high durability printhead design; and a light, strong, efficient motor. The long-last rack-and-pinion drive system and a protective, impact-resistance chassis, make it resilient even in the toughest environments. With a patented optical sensor that places the printhead for precise output, and the auto-tear feature that accurately positions your continuous forms for a clean tear, right at the perforation - eliminating wasted forms and facilitating your day-to-day forms printing.
The ML3320eco/ML3321eco have been developed to be eco-friendly. With power consumption at just 1.5W in sleep mode, your running costs and energy consumption are kept to a minimum, as well as reducing your carbon footprint.
OKI Microline 3321eco - printer - monochrome - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 9 pin - monochrome
7.6 kg
Max Media Size
Continuous paper 76.2 mm - 406.4 mm (width)
Min Media Size (Custom)
76.2 mm
Max Media Size (Custom)
406.4 mm
Print Speed
Up to 435 char/sec - super speed draft , Up to 387 char/sec - high speed draft , Up to 387 char/sec - high speed draft , Up to 290 char/sec - utility , Up to 290 char/sec - utility , Up to 73 char/sec - near letter , Up to 73 char/sec - near letter
Max Resolution (B&W)
240 x 216 dpi
Parallel, USB
RAM Installed (Max)
128 KB
Language Simulation
EPSON FX, Okidata Microline, IBM ProPrinter
Barcodes
Code 39, EAN/JAN-8 , EAN/JAN-13 , UPC-A, UPC-E, Interleaved 2 of 5, Postnet , OCR-B, Code 128B, Code 128C, Code 128A
Media Type
Envelopes, labels, plain paper, continuous forms
AC 230V
3 years warranty with product registration
55.2 cm x 34.5 cm x 11.6 cm
Printer Type
Printer
Print Speed
Up to 435 char/sec - super speed draft - 12 cpi , Up to 387 char/sec - high speed draft - 12 cpi , Up to 387 char/sec - high speed draft - 10 cpi , Up to 290 char/sec - utility - 12 cpi , Up to 290 char/sec - utility - 10 cpi , Up to 73 char/sec - near letter - 12 cpi , Up to 73 char/sec - near letter - 10 cpi
Wired
Parallel, USB
240 x 216 dpi
Language Simulation
Fonts Included
1 x scalable , 1 x barcode
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Path Type
Curved
Media Type
Max Media Size
76.2 mm
406.4 mm
Media Sizes
Envelope Sizes
Com-10 (105 x 241 mm)
Media Feeders
1 x manual - 1 sheet - continuous paper 76.2 mm - 406.4 mm (width)
Max Sheets in Multi-Part Form
5
1 x parallel - 36 PIN Centronics , 1 x USB - 4 PIN USB Type B
Consumables Included
1 x printhead - up to 200 million characters , 1 x ribbon - up to 3 million characters
MTBF
10,000 hour(s)
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
27.5 Watt
Power Consumption Stand by / Sleep
1.5 Watt
Environmental Standards
ENERGY STAR
Service & Support Details
Limited warranty - 3 years
Sound Emission (Operating)
57 dBA
Sound Emission (Quiet Mode)
52 dBA
55.2 cm
34.5 cm
11.6 cm
7.6 kg
Scroll to top
