BT.com
Wishlist
OKI Microline 280 Elite Mono Dot-Matrix Printer
OKI Microline 280 Elite Mono...
£229.89
15 in stock
£229.89
Add to wishlist
Delivery
Standard 1-3 working days
The Microline 280 Elite is Oki's smallest dot matrix printer offering perfect print quality at very low cost. High reliability and very compact dimensions make it especially suited for front/back office applications and industrial environments (multipart forms, logs, labels etc.) The Microline 280 Elite is ideal for integration into measurement and control systems.
OKI Microline 280 Elite - printer - monochrome - dot-matrix
Printer Type
Personal printer - dot-matrix - 9 pin - monochrome
4.5 kg
Media Size Class
Legal
Max Media Size
Legal (216 x 356 mm), continuous paper 76.2 mm - 254 mm (width)
Min Media Size (Custom)
76.2 mm
Max Media Size (Custom)
254 mm
Print Speed
Up to 375 char/sec - max speed , Up to 333 char/sec - fast draft , Up to 250 char/sec - normal , Up to 250 char/sec - normal , Up to 62.5 char/sec - near letter , Up to 62.5 char/sec - near letter
Max Resolution (B&W)
240 x 216 dpi
Parallel, USB
RAM Installed (Max)
128 KB
Language Simulation
EPSON FX, Okidata Microline, IBM Graphics
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, Code 128B, Code 128C, Code 128A
Media Type
Labels, plain paper, continuous forms, cards
Media Handling
Bottom paper feeder, rear paper feeder, top paper feeder
AC 230V
3 years warranty with product registration
37.2 cm x 27.5 cm x 8 cm
Printer Type
Printer
Print Speed
Up to 375 char/sec - max speed - 12 cpi , Up to 333 char/sec - fast draft - 10 cpi , Up to 250 char/sec - normal - 12 cpi , Up to 250 char/sec - normal - 10 cpi , Up to 62.5 char/sec - near letter - 12 cpi , Up to 62.5 char/sec - near letter - 10 cpi
Wired
Parallel, USB
240 x 216 dpi
Language Simulation
Fonts Included
1 x barcode , 1 x scalable
Barcodes
Media Handling
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Path Type
Curved, straight
Media Type
Media Size Class
Legal
Max Media Size
76.2 mm
254 mm
Media Sizes
Media Weight
35 g/m² - 90 g/m²
Media Feeders
1 x manual - 1 sheet - continuous paper 76.2 mm - 254 mm (width) weight: 35 g/m² - 52 g/m² , 1 x manual - 1 sheet - continuous paper 76.2 mm - 254 mm (width) weight: 35 g/m² - 52 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 50 g/m² - 90 g/m²
Max Sheets in Multi-Part Form
4
1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
Consumables Included
1 x ribbon ( black ) - up to 3 million characters , 1 x printhead - up to 200 million characters
MTBF
20,000 hour(s)
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
Software Included
Driver
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
Sound Emission (Operating)
51 dB
37.2 cm
27.5 cm
8 cm
4.5 kg
Accessories
£8.19
Scroll to top
