BT.com
Wishlist
OKI Microline 1190 - printer - monochrome - dot-matrix
OKI Microline 1190 - printer -...
£193.96
Hurry, only 2 left in stock!
£193.96
Add to wishlist
Delivery
Standard 1-3 working days
These compact and robust dot matrix printers not only produce great resolution output but also come with proven, class leading reliability. With USB fitted as standard, businesses can now enjoy greater flexibility and seamless connectivity, without having to compromise on price or performance.
Printer Type
Personal printer - dot-matrix - 24 pin - monochrome
4.2 kg
Max Media Size
Continuous paper 76.2 mm - 245 mm (width)
Max Media Size (Custom)
245 mm
Print Speed
Up to 333 char/sec - max speed , Up to 250 char/sec - normal , Up to 83 char/sec - letter
Max Resolution (B&W)
360 dpi
Parallel, USB, serial
RAM Installed (Max)
64 KB
Language Simulation
IBM AGM, IBM PPR, EPSON LQ
Barcodes
OCR-A, OCR-B
Media Type
Plain paper, continuous forms
AC 230V
3 years warranty with product registration
34.9 cm x 23.2 cm x 15 cm
Printer Type
Printer
Print Speed
Up to 333 char/sec - max speed - 10 cpi , Up to 250 char/sec - normal - 10 cpi , Up to 83 char/sec - letter - 10 cpi
Wired
360 dpi
Language Simulation
Fonts Included
1 x barcode , 1 x scalable
Barcodes
OCR-A, OCR-B
RAM
RAM Installed (Max)
64 KB
Media Handling
Media Type
Max Media Size
245 mm
Media Sizes
Media Feeders
1 x manual - 1 sheet - continuous paper 76.2 mm - 245 mm (width)
Max Sheets in Multi-Part Form
5
1 x parallel - 36 PIN Centronics , 1 x RS-232 - 25 pin D-Sub (DB-25) , 1 x USB - 4 pin USB Type B
Consumables Included
1 x ribbon (black) - up to 4 million characters , 1 x printhead - up to 400 million dots
MTBF
10,000 hour(s)
Power adapter - internal
AC 230V
Frequency Required
50/60 Hz
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
Sound Emission (Operating)
51 dBA
34.9 cm
23.2 cm
15 cm
4.2 kg
Scroll to top
