BT.com
Wishlist
OKI MC873dn A3 Colour Multifunction LED Laser Printer
OKI MC873dn A3 Colour Multifunction...
£2,385.18
Hurry, only 1 left in stock!
£2,385.18
Add to wishlist
Delivery
Standard 1-3 working days
Everything the small business or small to medium workgroup requires, in a compact size - The MC873dn is an MFP from OKI that combines color printing and copying, color/mono scanning with scan-to capabilities, and analog faxing - all in a compact Tabloid/A3 device that fits in just about any environment, so there's no need to sacrifice space for functionality.
OKI MC873DN - multifunction printer (colour)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
LED (colour)
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
10000 pages
Max Copying Speed
Up to 35 ppm (mono) / up to 35 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Display
7"
Original Size
A6 (105 x 148 mm) (min) - 297 x 431.8 mm (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
A6 (105 x 148 mm) (min) - 297 x 1321 mm (max)
Media Type
Transparencies, envelopes, plain paper, labels, banner
Standard Media Capacity
400 sheets
Max Media Capacity
2005 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
450 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, Google Cloud Print ready, AirPrint ready
AC 230 V (50/60Hz)
56.3 cm x 60 cm x 70 cm
64 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3 years warranty with product registration
Fax Type
Plain paper
Printing Technology
LED - colour
75000 pages
10000 pages
Display Diagonal Size
7"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
1.25 GB
Hard Disk Drive
250 GB
Copying
Max Copying Speed
Preset Enlargements
400%
Preset Reductions
25%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, IBM Proprinter, PDF 1.7, XPS, EPSON FX
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
9.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Colour Depth
24 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 400 pages
Fax Machine Features
One-Touch Dialing
40 station(s)
Speed Dialing
1000 station(s)
Broadcast Transmission
100 stations
Group dialling
Document & Media Handling
Min Original Size
A6 (105 x 148 mm)
Max Original Size
297 x 431.8 mm
Original Type
Sheets
100 sheets
Min Media Size
A6 (105 x 148 mm)
Max Media Size
A3
Min Media Weight
60 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International C4 (229 x 324 mm)
400 sheets
Max Media Capacity
2005 sheets
100 sheets
450 sheets
RADF - 100 sheets size: B5 (176 x 250 mm) - A3 (297 x 420 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: A6 (105 x 148 mm) - 297 x 1321 mm weight: 64 g/m² - 256 g/m² , Input tray - 300 sheets size: B5 (176 x 250 mm) - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m²
Speed Details
Copying: up to 35 ppm (A4) - B/W , Copying: up to 35 ppm (A4) - colour , Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (A4) - colour , Printing: up to 20 ppm (A3) - B/W , Printing: up to 20 ppm (A3) - colour , Scanning: up to 50 spm - B/W , Scanning: up to 50 spm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host - 4 pin USB Type A
Security Protocols & Features
LDAP, SSL, TLS, IPsec, 802.1x, IP filtering, MAC address filtering
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.6.8 - 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
Software Included
OKI PrintSuperVision, OKI Color Swatch Utility, OKI Template Manager, OKI LPR, ABBYY FineReader 12 Sprint, SENDYS Explorer LITE
AC 230 V (50/60Hz)
1400 Watt
Power Consumption Standby
120 Watt
Power Consumption Sleep
30 Watt
Warm-Up Time
32 sec
First Copy Out Time B/W
10 sec
First Copy Out Time Colour
10 sec
Consumables Included
1 x Cartridge (black) - up to 2500 pages , 1 x Cartridge (cyan) - up to 2500 pages , 1 x Cartridge (magenta) - up to 2500 pages , 1 x Cartridge (yellow) - up to 2500 pages
ENERGY STAR Certified
Limited warranty - 3 years
56.3 cm
60 cm
70 cm
64 kg
Sound Emission
37 dBA (idle) / 54 dBA (operating)
10 °C
32 °C
20 - 80%
Scroll to top
