BT.com
Wishlist
OKI MC851dn Colour Laser Multifunction Printer
OKI MC851dn Colour Laser...
£1,742.28
£1,742.28
Add to wishlist
Delivery
Standard Due date unavailable
The MC851 is a truly integrated, network ready multifunction product that can print, copy, scan and fax bringing extra productivity, capability and cost-savings to the busy workgroup and small business. With networking as standard, the MC851cdtn also has integrated duplex capabilities, for double-sided printing. The cabinet provides extra storage space whilst the 2nd tray provides an additional 530-sheet capacity allowing print to continue for longer without user intervention.
OKI MC851dn - multifunction printer (colour)
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
LED (colour)
Monthly Duty Cycle (max)
60000 impressions
Recommended Monthly Volume
8000 pages
Max Copying Speed
Up to 34 ppm (mono) / up to 22 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Original Size
A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Media Type
Envelopes, plain paper
Standard Media Capacity
400 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
PC Connection Availability
PC Connection
Parallel, USB 2.0, LAN
Office Machine Features
Save to USB flash drive, scan to e-mail
AC 230 V (50/60Hz)
56.5 cm x 65.8 cm x 66.9 cm
68 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty with product registration
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
LED - colour
60000 impressions
8000 pages
Display Features
Touch screen
PC Connection
Standard Memory
512 MB
Max Supported Memory
768 MB
Hard Disk Drive
40 GB
Copying
Max Copying Speed
Preset Enlargements
400%
Preset Reductions
25%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
11.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Colour Depth
24 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 1000 pages
Fax Machine Features
Speed Dialing
500 station(s)
Broadcast Transmission
530 stations
Group dialling
Document & Media Handling
Max Original Size
A3 (297 x 420 mm)
Original Type
Sheets
50 sheets
Max Media Size
A3
Min Media Weight
42 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
400 sheets
100 sheets
250 sheets
ADF - 50 sheets - A3 (297 x 420 mm) weight: 42 g/m² - 128 g/m² , Bypass tray - 100 sheets - 297 x 1200 mm weight: 64 g/m² - 200 g/m² , Input tray - 300 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 120 g/m² , Output tray - 250 sheets
Speed Details
Copying: up to 34 ppm (A4) - B/W , Copying: up to 22 ppm (A4) - colour , Printing: up to 34 ppm (A4) - B/W , Printing: up to 22 ppm (A4) - colour , Printing: up to 17 ppm (A3) - B/W , Printing: up to 12 ppm (A3) - colour
1 x USB 2.0 , 1 x parallel , 1 x LAN
Network Protocols
TCP/IP, NetBEUI, LPR/LPD, SMB, SNMP, HTTP, HTTPS, IPv4, IPv6, Bonjour, FTP, SMTP
Security Protocols & Features
Kerberos, Secure Print, SSL, TLS, IPsec, 802.1x
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), Apple MacOS X 10.3.9 or later, MS Windows Server 2008, MS Windows Server 2008 R2
Software Included
OKI Colour Correct Utility, OKI Print Control Software, OKI LPR, OKI Storage Device Manager, Nuance PaperPort SE 11, Nuance OmniPage SE 16
AC 230 V (50/60Hz)
700 Watt
Power Consumption Standby
160 Watt
Power Consumption Sleep
25 Watt
Warm Up Time
90 sec
First Copy Out Time B/W
13 sec
First Copy Out Time Colour
16 sec
Consumables Included
1 x Cartridge (black) - up to 2000 pages , 1 x Cartridge (cyan) - up to 2000 pages , 1 x Cartridge (magenta) - up to 2000 pages , 1 x Cartridge (yellow) - up to 2000 pages
Limited warranty - 3 years
56.5 cm
65.8 cm
66.9 cm
68 kg
Sound Emission
37 dBA (idle) / 54 dBA (operating)
10 °C
32 °C
20 - 80%
Scroll to top
