BT.com
Wishlist
OKI MC760dnfax A4 Colour Multifunction Printer
OKI MC760dnfax A4 Colour...
£1,430.40
£1,430.40
Add to wishlist
Delivery
Standard Due date unavailable
The MC760 improves the way that documents are handled, managed and processed through an organization, delivering workflow efficiencies at every level. Combining print, copy, scan, fax (MC760dnfax) and stapling functionality in one high speed, ergonomic device, the MC760 offers efficient and secure document input, throughput and output.
OKI MC760dnfax - multifunction printer (colour)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
LED (colour)
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
6000 pages
Max Copying Speed
Up to 28 ppm (mono) / up to 28 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Original Size
148.5 x 210 mm (min) - 216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
64 x 127 mm (min) - 216 x 1321 mm (max)
Media Type
Envelopes, plain paper, labels
Standard Media Capacity
630 sheets
Max Media Capacity
3160 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
520 sheets
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, scan to network, save to HDD, sXP (smart Extendable Platform)
AC 230 V (50/60Hz)
52.2 cm x 60.4 cm x 67.5 cm
50 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3 years warranty with product registration
Fax Type
Plain paper
Printing Technology
LED - colour
100000 pages
6000 pages
Display Features
Touch screen
PC Connection
Standard Memory
2 GB
Hard Disk Drive
160 GB
Copying
Max Copying Speed
Preset Enlargements
400%
Preset Reductions
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PCL 5c
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
First Print Out Time B/W
8 sec
First Print Out Time Colour
9 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Colour Depth
24 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 1000 pages
Fax Machine Features
Speed Dialing
1000 station(s)
Broadcast Transmission
400 stations
Group dialling
Document & Media Handling
Min Original Size
148.5 x 210 mm
Max Original Size
216 x 356 mm
Original Type
Sheets
100 sheets
Min Media Size
64 x 127 mm
Max Media Size
A4
Min Media Weight
64 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
630 sheets
Max Media Capacity
3160 sheets
100 sheets
520 sheets
RADF - 100 sheets - 216 x 356 mm weight: 60 g/m² - 105 g/m² weight (lbs): , Bypass tray - 100 sheets size: 64 x 127 mm - 216 x 1321 mm weight: 64 g/m² - 250 g/m² weight (lbs): , Input tray - 530 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² weight (lbs): , Output tray - 500 sheets weight (lbs): , Stapler - 20 sheets weight (lbs):
Speed Details
Copying: up to 28 ppm (A4) - B/W , Copying: up to 28 ppm (A4) - colour , Printing: up to 28 ppm (A4) - B/W , Printing: up to 28 ppm (A4) - colour , Scanning: up to 40 ipm - B/W , Scanning: up to 40 ipm - colour
Finishing Equipment
Stapler
Included
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, Secure Print, SSL, Apple Bonjour, TLS, IP filtering, ARP, MAC address filtering
Operating System Support
UNIX, Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, Apple Mac OS X 10.4, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista SP1, MS Windows 7 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista SP2, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Vista SP2 64-bit Edition, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2008 SP1, MS Windows Server 2003 SP2, Windows 8 64-bit
Software Included
Drivers & Utilities, OKI Job Accounting, OKI PrintSuperVision, OKI Template Manager
AC 230 V (50/60Hz)
800 Watt
Power Consumption Standby
130 Watt
Power Consumption Sleep
2 Watt
Warm Up Time
60 sec
First Copy Out Time B/W
13 sec
First Copy Out Time Colour
13 sec
Consumables Included
1 x Cartridge (black) - up to 4800 pages , 1 x Cartridge (cyan) - up to 4800 pages , 1 x Cartridge (magenta) - up to 4800 pages , 1 x Cartridge (yellow) - up to 4800 pages
GS
Limited warranty - 3 years - on-site
52.2 cm
60.4 cm
67.5 cm
50 kg
Sound Emission
37 dBA (idle) / 57 dBA (operating)
10 °C
32 °C
20 - 80%
Scroll to top
