BT.com
Wishlist
OKI MC362dn Mono LED Multifunction Printer
Delivery
Standard Due date unavailable
With color print speeds of 22ppm and mono print speeds of 24ppm, the MC362dn is perfect for small businesses or workgroups providing a variety of functions and the flexibility of printing, scanning, copying and faxing in-house. Helping to manage your internal documents and those you receive, the MC362dn allows you to work smarter and manage your document flow throughout your business or workgroup.
The MC362dn offers duplex printing, scanning, copying and faxing as standard, with an automatic RADF, combined with superior quality high definition color and mono A4 printing that enables you to produce professional looking documents in-house.
OKI MC362dn - multifunction printer ( colour )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
LED ( colour )
Monthly Duty Cycle (max)
45000 impressions
Recommended Monthly Volume
3000 pages
Max Copying Speed
Up to 24 ppm (mono) / up to 22 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Display
3.5"
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
210 x 1320 mm (max)
Media Type
Envelopes, plain paper, cards, banner
Standard Media Capacity
350 sheets
Max Media Capacity
880 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail
AC 230 V ( 50/60Hz )
42.7 cm x 50.9 cm x 44.4 cm
29 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3 years warranty with product registration
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
LED - colour
45000 impressions
3000 pages
Display Diagonal Size
3.5"
PC Connection
Standard Memory
256 MB
Max Supported Memory
768 MB
Copying
Max Copying Speed
Preset Enlargements
400%
Preset Reductions
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, IBM Proprinter
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
First Print Out Time B/W
8.5 sec
First Print Out Time Colour
9 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 200 pages
Fax Machine Features
One Touch Dialing
16 station(s)
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Group dialling
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
50 sheets
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Borderless Photo Sizes
102 x 152 mm, 76 x 127 mm, 127 x 178 mm
350 sheets
Max Media Capacity
880 sheets
100 sheets
150 sheets
ADF - 50 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 100 sheets - 210 x 1320 mm weight: 64 g/m² - 220 g/m² , Input tray - 250 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 176 g/m² , Output tray - 150 sheets
Speed Details
Copying: up to 24 ppm - B/W , Copying: up to 22 ppm - colour , Printing: up to 24 ppm ( A4 ) - B/W , Printing: up to 22 ppm ( A4 ) - colour , Scanning: up to 20 spm - colour , Scanning: up to 30 spm - B/W
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
TCP/IP, NetBEUI, LPR/LPD, RAW IP (Port 9100), SNMP, HTTP, IPv4, IPv6, Bonjour, FTP, SMTP, DHCP, BOOTP
Security Protocols & Features
SSL, TLS, IPsec, 802.1x, IP filtering, MAC address filtering
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.3.9 - 10.7
Software Included
OKI PrintSuperVision, OKI Colour Swatch Utility, OKI Colour Correct Utility, OKI Template Manager, OKI LPR, Nuance PaperPort SE 11, Nuance OmniPage SE 16
500 Watt
Power Consumption Standby
100 Watt
Power Consumption Sleep
20 Watt
First Copy Out Time B/W
12 sec
First Copy Out Time Colour
14 sec
Consumables Included
1 x Cartridge ( black ) - up to 1000 pages , 1 x Cartridge ( cyan ) - up to 1000 pages , 1 x Cartridge ( magenta ) - up to 1000 pages , 1 x Cartridge ( yellow ) - up to 1000 pages
Supported Windows 7 Features
Windows HD Imaging
Limited warranty - 3 years
42.7 cm
50.9 cm
44.4 cm
29 kg
Sound Emission
33 dBA (idle) / 52 dBA (operating)
10 °C
32 °C
20 - 80%
Accessories
OKI C510DN/C330/C310/C530 Yellow Toner
Quicklinx: 75P8 | In Stock
£69.08
OKI C510DN/C330/C310/C530 Magenta Toner
Quicklinx: 75PD | In Stock
£69.08
OKI C510DN/C330/C310/C530 Cyan
Quicklinx: 75PF | In Stock
£69.08
OKI C310/330/510/530 Black Toner
Quicklinx: 75PG | In Stock
£51.67
OKI Belt Unit - C510DN/C330/C310/C530
Quicklinx: 84VD | In Stock
£55.71
OKI C310/321/510/530/MC351 Fuser Unit
Quicklinx: 84VH | In Stock
£55.71
Scroll to top
