BT.com
Wishlist
OKI MB770dfn Mono Laser Multifunction Printer
OKI MB770dfn Mono Laser...
£2,175.70
£2,175.70
Add to wishlist
Delivery
Standard Due date unavailable
The OKI MB770 mono MFP series combines high-quality output and four-in-one functionality with speed, reliability and ease of use - superior value from MFP that has a footprint small enough to fit easily into your environment. The MB770 has a robust super G3 fax with dual access, T.37 Internet faxing, a 3,000-entry address book, double-sided fax scanning, and the ability to let you send faxes directly from your PC. It can make your job easier - the MB770 MFP series is user friendly: network-ready right out of the box, with an intuitive operator panel that's simple to use: a 9" color touch-screen graphic display, an alphanumeric keypad and function buttons.
OKI MB 770dfnfax - multifunction printer ( B/W ) - with 500-sheets Finisher
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
LED ( monochrome )
Monthly Duty Cycle (max)
200000 pages
Recommended Monthly Volume
30000 pages
Max Copying Speed
Up to 52 ppm
Max Copying Resolution
Up to 600 dpi
Max Printing Speed
Up to 52 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
64 x 127 mm (min) - 216 x 1321 mm (max)
Media Type
Envelopes, plain paper, labels
Standard Media Capacity
630 sheets
Max Media Capacity
3160 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
600 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder
AC 230 V ( 50/60Hz )
52.2 cm x 56.4 cm x 81.1 cm
60 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty with product registration
Bundled with
500-sheets Finisher
Fax Type
Plain paper
Printing Technology
LED - monochrome
200000 pages
30000 pages
Display Features
Touch screen
PC Connection
Bundled with
500-sheets Finisher
Standard Memory
2 GB
Hard Disk Drive
160 GB
Copying
Max Copying Speed
Up to 52 ppm
Up to 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
ID Card Copy, Job Build
Printing
Max Printing Speed
Up to 52 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PCL 5c, PDF, XPS
Automatic Duplexing
First Print Out Time B/W
5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Colour Depth
24 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Machine Features
Speed Dialing
3000 station(s)
Broadcast Transmission
400 stations
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
100 sheets
Min Media Size
64 x 127 mm
Max Media Size
A4
Min Media Weight
64 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
630 sheets
Max Media Capacity
3160 sheets
100 sheets
600 sheets
Bypass tray - 100 sheets size: 64 x 127 mm - 216 x 1321 mm weight: 64 g/m² - 250 g/m² , Input tray - 530 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Output tray - 100 sheets , ADF - 100 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m²
Speed Details
Copying: up to 52 ppm - B/W , Printing: up to 52 ppm - B/W , Scanning: up to 40 ipm - colour , Scanning: up to 55 ipm - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45 , 2 x modem - RJ-11
Security Protocols & Features
LDAP, Secure Print, SSL, TLS
Operating System Support
UNIX, Linux, MS Windows XP SP2 or later, Apple Mac OS X 10.4, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista SP1, MS Windows 7 64-bit Edition, MS Windows Vista SP2, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Vista SP2 64-bit Edition, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2008 SP1, MS Windows Server 2003 SP2, Windows 8 64-bit, MS Windows Server 2012 x64 Edition
870 Watt
Power Consumption Sleep
2 Watt
First Copy Out Time B/W
8 sec
Consumables Included
1 x Cartridge ( black ) - up to 10000 pages
GS
Limited warranty - 3 years - on-site
52.2 cm
56.4 cm
81.1 cm
60 kg
Sound Emission
30 dBA (idle) / 58 dBA (operating)
10 °C
32 °C
20 - 80%
Other bundles
£2,175.70
Save on TP Link Smart Plug
Save £2.00
£2,199.67
Scroll to top
