BT.com
Wishlist
OKI MB 471W Mono LED Multifunction Printer
Delivery
Standard Due date unavailable
The MB400 MFP series from OKI printing solutions combines black and white printing and copying, color/mono scanning, analog faxing, and scan-to capabilities. These affordable, compact, networked MFPs let you produce professional-looking documents - with productivity-boosting speeds and budget-enhancing efficiency - and distribute them with ease through simple, user-friendly steps.
OKI MB 471W - multifunction printer (B/W)
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
LED (monochrome)
Monthly Duty Cycle (max)
70000 impressions
Recommended Monthly Volume
5000 pages
Max Copying Speed
Up to 33 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 33 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Display
3.5"
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
210 x 1321 mm (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
350 sheets
Max Media Capacity
880 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
Office Machine Features
Scan to e-mail, scan to folder, scan to application, scan to network
AC 230 V (50/60Hz)
42.7 cm x 42.5 cm x 45.5 cm
20 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty with product registration
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
LED - monochrome
70000 impressions
5000 pages
Display Diagonal Size
3.5"
PC Connection
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Up to 33 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 33 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, IBM Proprinter
Automatic Duplexing
First Print Out Time B/W
5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 200 pages
Fax Machine Features
One Touch Dialing
16 station(s)
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
50 sheets
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
160 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
350 sheets
Max Media Capacity
880 sheets
100 sheets
150 sheets
Bypass tray - 100 sheets - 210 x 1321 mm weight: 60 g/m² - 160 g/m² , Input tray - 250 sheets size: A6 (105 x 148 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Output tray - 150 sheets , ADF - 50 sheets size: A6 (105 x 148 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m²
Speed Details
Copying: up to 33 ppm - B/W , Printing: up to 33 ppm - B/W , Scanning: up to 37.5 ppm - B/W , Scanning: up to 10 ppm - colour
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
TCP/IP, LPR/LPD, RAW IP (Port 9100), SNMP, HTTP, IPv4, IPv6, Bonjour, FTP, SMTP, DHCP, BOOTP
Security Protocols & Features
SSL, WEP, TLS, WPA, WPA2, IPsec, 802.1x, TKIP, AES, IP filtering, MAC address filtering
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.4 - 10.7, MS Windows Server 2008 R2 x64 Edition
Software Included
OKI PrintSuperVision, OKI Template Manager, OKI Network Setup Tool, OKI LPR, Nuance PaperPort SE 11, Nuance OmniPage SE 16
AC 230 V (50/60Hz)
580 Watt
Power Consumption Standby
80 Watt
Power Consumption Sleep
18 Watt
First Copy Out Time B/W
11 sec
Consumables Included
1 x Cartridge (black) - up to 2000 pages , 1 x drum (black) - up to 25000 pages
Limited warranty - 3 years
42.7 cm
42.5 cm
45.5 cm
20 kg
Sound Emission
30 dBA (idle) / 55 dBA (operating)
10 °C
32 °C
20 - 80%
Accessories
OKI 44574302 Drum
Quicklinx: 7B4Y | In Stock
£99.22
OKI B411/B431/MB461/491 BK Toner (3K)
Quicklinx: 85P3 | In Stock
£70.39
OKI B431/MB461/471/491 Black Toner 7K
Quicklinx: 8S99 | In Stock
£107.74
Scroll to top
