BT.com
Wishlist
OKI C833dn-2AC A4 A3 Colour Laser Printer
OKI C833dn-2AC A4 A3 Colour Laser...
£1,066.62
12 in stock
£1,066.62
Add to wishlist
Delivery
Standard 1-3 working days
Key features
  • Smallest footprint A3 printer on the market perfect for retail
  • Excellent media flexibility - A6 to A3 and up to 1321mm banners
  • Up to 35ppm colour print speed
  • Fast duplex printing (optional on n variants)
  • Paper capacity up to 1990 sheets and media weights between 64 and 256gsm
  • Excellent 1200 x 1200dpi print quality (C843dn)
  • Citrix XenApp 7.6 compatibility - ideal for virtual network environment
Important security features
  • Keep documents confidential with Private Print and optional Card Release* so users can view all print jobs before selecting which ones to print
  • Internet Protocol Security (IPSec) compliance ensuring securing that documents are safely sent and received
Easy to use
  • Easy to set-up and get started
  • Store templates and documents on the device for all users to print without authentication (Shared Print)
  • When new features are available you can update the device via the OKI portal
Advanced connectivity
  • Wireless Direct offers safe simultaneous connection of wired and wireless networking
  • Optional Wireless LAN Module available
  • Gigabit Ethernet enables fast transfer of large colour files across the network
  • Google Cloud Print 2.0 ready enabling printing on the move
Cost and energy saving
  • Print marketing materials in-house thanks to outstanding print quality and media flexibility
  • Deep Sleep mode saves energy Auto-Off mode automatically powers down to less than 0.5W when not in use
  • Toner Save to reduce cost when printing draft or internal documents
  • Duplex printing reduces paper usage
  • Mono only printing when colour cartridges are empty
  • Free consumables recycling programme
  • LED technology means no moving parts for a longer life
OKI C833dn - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
40 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Min Media Size (Custom)
148.5 mm x 182 mm
Max Media Size (Custom)
297 mm x 1321 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm) , Up to 20 ppm - B/W - A3 (297 x 420 mm) , Up to 20 ppm - colour - A3 (297 x 420 mm)
Max Resolution (B&W)
1200 x 600 dpi
Max Resolution (Colour)
1200 x 600 dpi
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
RAM Installed (Max)
256 MB (768 MB)
Flash Memory Installed (Max)
(16 GB)
Language Simulation
PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, XPS, SIDM, PCL XL 3.0, PDF 1.7
Barcodes
Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
Media Type
Envelopes, plain paper
Total Media Capacity
400 sheets
Media Handling
100-sheet multipurpose tray, 300-sheet input tray
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
5000 pages
Print server
AC 230V
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Apple MacOS X 10.8.5 - 10.11
3 years warranty with product registration
44.9 cm x 55.2 cm x 36 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 600 dpi
1200 x 600 dpi
Automatic Duplexing
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
9.5 sec
Language Simulation
Fonts Included
87 x scalable PCL , 80 x PostScript , 1 x bitmapped PCL , 1 x barcode
Barcodes
Media Handling
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Flash Memory
Flash Memory
16 GB (max)
Card Reader
Supported Flash Memory Cards
SDHC Memory Card
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
148.5 mm x 182 mm
297 mm x 1321 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), International C4 (229 x 324 mm)
Media Weight
64 g/m² - 256 g/m²
400 sheets
Media Feeders
1 x automatic - 300 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets weight: 64 g/m² - 256 g/m²
Max Media Capacity
2005 sheets
Output Trays Capacity
250 sheets
Duty Cycle
75000 pages
5000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, HTTP
Security Protocols & Features
SSL, TLS, IPsec, 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2500 pages ISO/IEC 19798
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
700 Watt
Power Consumption Stand by
12 Watt
Power Consumption Sleep
1 Watt
Software Included
OKI PrintSuperVision, OKI LPR, OKI Web Driver Installer, OKI Profile Assistant, OKI Color Correct, OKI Color Swatch Utility, OKI Network Extension, OKI Template Manager, OKI PS Gamma Adjuster, OKI Print Job Accounting, OKI Configuration Tool, OKI Firmware Update Tool, OKI Network Card Setup
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
32 dBA
Sound Emission (Operating)
52 dBA
44.9 cm
55.2 cm
36 cm
40 kg
Scroll to top
