BT.com
Wishlist
OKI C831n Colour LED Printer
£873.32
£873.32
Add to wishlist
Delivery
Standard Due date unavailable
The C831 is the ideal A3/A4 color printer for small to medium businesses or workgroups looking for fast, high quality, high volume, print on demand capabilities, in-house. With fast print speeds and high capacity toners, you can rely on this device to deliver on your day-to-day business printing needs.
OKI C831n - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
37 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Max Media Size (Custom)
297 mm x 1321 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm) , Up to 20 ppm - B/W - A3 (297 x 420 mm) , Up to 20 ppm - colour - A3 (297 x 420 mm)
Max Resolution (B&W)
1200 x 600 dpi
Max Resolution (Colour)
1200 x 600 dpi
Image Enhancement Technology
OKI ProQ2400 Multilevel
USB, LAN, USB host
800 MHz
RAM Installed (Max)
256 MB (768 MB)
Card Reader
Language Simulation
PCL 5C, PostScript 3, PCL 6, SIDM, PDF 1.8
Barcodes
OCR-A, OCR-B, ZIP
Media Type
Envelopes, plain paper, banners
Total Media Capacity
400 sheets
Media Handling
100-sheet multipurpose tray, 300-sheet input tray
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
1500 - 5000 pages
Print server - Ethernet, Fast Ethernet - internal
Printer Features
Optional duplex
AC 230V
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.3.9 - 10.7
Microsoft Certification
Compatible with Windows 7
3 years warranty with product registration
44.9 cm x 55.2 cm x 36 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN, USB host
1200 x 600 dpi
1200 x 600 dpi
PostScript Support
Standard
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
9.5 sec
Language Simulation
Fonts Included
87 x scalable PCL , 80 x scalable PostScript , 1 x bitmapped PCL , 1 x barcode
Barcodes
OCR-A, OCR-B, ZIP
Colour Management Features
ICC Color Profiles
Printer Features
Optional duplex
Media Handling
800 MHz
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SDHC Memory Card
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
297 mm x 1321 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), International C4 (229 x 324 mm)
Media Weight
64 g/m² - 256 g/m²
400 sheets
Media Feeders
1 x automatic - 300 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets - 297 x 1321 mm weight: 64 g/m² - 256 g/m²
Max Media Capacity
1990 sheets
Output Trays Capacity
250 sheets
Duty Cycle
75000 pages
1500 - 5000 pages
Print server - internal
Remote Management Protocol
SNMP 3, HTTPS
Security Protocols & Features
Secure Print, SSL, TLS, 802.1x, IP filtering, MAC address filtering
Expansion Slots
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x direct print port - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2500 pages ISO/IEC 19798
Supported Windows 7 Features
Windows HD Imaging
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
700 Watt
Power Consumption Stand by / Sleep
100 Watt
Software Included
OKI PrintSuperVision, OKI LPR, OKI PrintSuperVision.net, OKI Web Driver Installer, OKI Web Print, OKI Profile Assistant, OKI Storage Device Manager, OKI Color Correct, OKI Color Swatch Utility, OKI Template Manager, OKI PDF Direct Utility, OKI PS Gamma Adjuster, OKI Color Access Policy Manager
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
32 dBA
Sound Emission (Operating)
52 dBA
44.9 cm
55.2 cm
36 cm
37 kg
Accessories
OKI C831/841 Black Toner 10K
Quicklinx: 8SB6 | In Stock
£78.13
OKI C831/841 Cyan Toner 10K
Quicklinx: 8SB8 | In Stock
£173.50
OKI C831/841 Magenta Toner 10K
Quicklinx: 8SB9 | In Stock
£173.50
OKI C831/841 Yellow Toner 10K
Quicklinx: 8SBC | In Stock
£173.50
OKI C822/831/841 MAGENTA Image Drum 30K
Quicklinx: 8SBL | In Stock
£122.00
OKI C822/831/841 Cyan Image Drum 30K
Quicklinx: 8SBM | In Stock
£122.00
OKI C822/831/841 Black Image Drum 30K
Quicklinx: 8SBN | In Stock
£122.00
OKI C831/C841 Fuser Unit
Quicklinx: 8SBR | In Stock
£82.34
OKI C822/831/841 Transfer Belt
Quicklinx: 8SBS | In Stock
£84.84
Scroll to top
