BT.com
Wishlist
OKI C712dn-2AC A4 Colour Laser Printer
OKI C712dn-2AC A4 Colour Laser...
£778.83
£778.83
Add to wishlist
Delivery
Standard 1-3 working days
When productivity in the workplace really matters if your team is taking on tight deadlines and demanding workloads you need a network colour printer you can really depend on. The ultra-reliable digital LED technology rapid throughput and a robust yet compact design deliver enterprise-class performance that just won’t let you down.
And that’s not all. With its superb print quality exceptional media flexibility superior energy efficiency and a genuinely low total cost of ownership the C711 is a solid investment in the future of your business.
OKI C712dn - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
32 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm x 1321 mm
Print Speed
Up to 36 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 600 dpi
Max Resolution (Colour)
1200 x 600 dpi
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
USB, Gigabit LAN
RAM Installed (Max)
256 MB (768 MB)
Flash Memory Installed (Max)
(16 GB)
Language Simulation
PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, XPS, SIDM, PCL XL 3.0, PDF 1.7
Barcodes
Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, ZIP
Media Type
Envelopes, labels, plain paper, banner paper
Total Media Capacity
630 sheets
Media Handling
100-sheet multipurpose tray, 530-sheet input tray
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
6000 pages
Print server
AC 230V
Linux, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Vista / 7 / 8 / 8.1 / 10 (32/64 bits), Apple MacOS X 10.8.5 - 10.11
3 years warranty with product registration
43.5 cm x 60.4 cm x 38.9 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, Gigabit LAN
1200 x 600 dpi
1200 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
8 sec
First Print Out Time Colour
9 sec
Language Simulation
Fonts Included
80 x PostScript , 87 x PCL
Barcodes
Media Handling
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Flash Memory
Flash Memory
16 GB (max)
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
216 mm x 1321 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
64 g/m² - 250 g/m²
630 sheets
Media Feeders
1 x automatic - 530 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 250 g/m²
Max Media Capacity
1690 sheets
Output Trays Capacity
350 sheets
Duty Cycle
100000 pages
6000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, HTTP, NDPS, NDS, HTTPS
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
600 Watt
Power Consumption Stand by
1.2 Watt
Software Included
OKI PrintSuperVision, OKI LPR, OKI Web Driver Installer, OKI Profile Assistant, OKI Color Correct, OKI Template Manager, OKI PDF Print Direct, OKI PS Gamma Adjuster, OKI Network Set Up, OKI Colour Swatch, OKI Print Job Accounting
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
54 dBA
43.5 cm
60.4 cm
38.9 cm
32 kg
Scroll to top
