BT.com
Wishlist
OKI C711N A4 Colour Laser
Delivery
Standard Due date unavailable
When productivity in the workplace really matters, if your team is taking on tight deadlines and demanding workloads, you need a network color printer you can really depend on. The ultra-reliable digital LED technology, rapid throughput and a robust yet compact design deliver enterprise-class performance that just won't let you down.
And that's not all. With its superb print quality, exceptional media flexibility, superior energy efficiency and a genuinely low total cost of ownership, the C711 is a solid investment in the future of your business.
OKI C711n - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
28 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 36 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 600 dpi
Max Resolution (Colour)
1200 x 600 dpi
Image Enhancement Technology
OKI ProQ2400 Multilevel
Parallel, USB, LAN
533 MHz
RAM Installed (Max)
256 MB ( 768 MB )
Flash Memory Installed (Max)
( 16 GB )
Language Simulation
PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, XPS, SIDM, PCL XL 3.0, PDF 1.7
Barcodes
UPC-A, UPC-B, ZIP
Media Type
Envelopes, transparencies, labels, plain paper, banner paper
Total Media Capacity
630 sheets
Media Handling
100-sheet multipurpose tray, 530-sheet input tray
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
6000 pages
Print server - Ethernet, Fast Ethernet - internal
Printer Features
Optional duplex
AC 230V
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9, Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition
Microsoft Certification
Compatible with Windows 7
3 years warranty with product registration
43.5 cm x 54.6 cm x 38.9 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
Parallel, USB, LAN
1200 x 600 dpi
1200 x 600 dpi
PostScript Support
Standard
First Print Out Time B/W
8 sec
First Print Out Time Colour
9 sec
Language Simulation
Fonts Included
136 x PostScript , 87 x PCL
Barcodes
UPC-A, UPC-B, ZIP
Printer Features
Optional duplex
Media Handling
533 MHz
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Flash Memory
Flash Memory
16 GB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
64 g/m² - 250 g/m²
630 sheets
Media Feeders
1 x automatic - 530 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 250 g/m²
Max Media Capacity
1690 sheets
Output Trays Capacity
350 sheets
Duty Cycle
100000 pages
6000 pages
Print server - internal
Network / Transport Protocol
TCP/IP, UDP/IP, NetBEUI/NetBIOS, ICMP/IP, LPR/LPD, ARP, SMTP, FTP, BOOTP, DHCP, DNS, POP3, SMB
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, HTTP, NDPS, NDS
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x
Expansion Slots
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel
Supported Windows 7 Features
Windows HD Imaging
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
600 Watt
Power Consumption Stand by / Sleep
1.2 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
54 dBA
43.5 cm
54.6 cm
38.9 cm
28 kg
Accessories
OKI Yellow Toner 11,5000 pages
Quicklinx: 6LJF | In Stock
£173.47
OKI C710/C711 Magenta Toner
Quicklinx: 6LJT | In Stock
£173.47
OKI Cyan toner for C711
Quicklinx: 6LJV | In Stock
£173.47
OKI C710/C711 Black Toner - 11K
Quicklinx: 6MXR | In Stock
£98.52
OKI C711 EP C711 Image Drum Black
Quicklinx: 7LRR | In Stock
£63.46
OKI C711 Cyan Image Drum
Quicklinx: 7LRS | In Stock
£115.56
OKI C711 Magenta Image Drum
Quicklinx: 7LRV | In Stock
£115.56
OKI C711 Yellow Image Drum
Quicklinx: 7LRW | In Stock
£115.56
Scroll to top
