BT.com
Wishlist
OKI C610dn Colour Laser Printer
£341.65
£341.65
Add to wishlist
Delivery
Standard Due date unavailable
If you need a color printer that's fast and robust enough to take care of the needs of your entire team - even at the busiest times - look no further than the C610. Rapid print speeds, class leading media handling, and low energy consumption all combine to make this printer the ideal solution to effortlessly support business workgroups of up to 10 users.
The C610's ability to print on paper stocks of up to 250gsm coupled with Oki's High Definition Color technology means your business can produce color vibrant professional documents in-house with ease. Allowing you to print what you want, when you want it, avoiding unnecessary wastage costs and delays.
The C610 delivers maximum performance at exceptional value for money. Taking care to keep costs to a minimum the C610 has an attractive price tag, high yield toners and a long life image drum. In addition, included ‘in the box' are 3 utilities - print control, color access policy manager and PrintSuperVision. With features allowing you to track, monitor and control print usage and costs.
With networking as standard, the C610dn also has integrated duplex capabilities, for double-sided printing.
OKI C610dn - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
29 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 36 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 600 dpi
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
USB, LAN
533 MHz
RAM Installed (Max)
256 MB ( 768 MB )
Flash Memory Installed (Max)
( 16 GB )
Language Simulation
PCL 5C, PostScript 3, PCL 6, XPS, SIDM, PDF 1.7
Barcodes
UPC-A, UPC-B, ZIP
Media Type
Envelopes, labels, plain paper
Total Media Capacity
400 sheets
Media Handling
100-sheet multipurpose tray, 300-sheet input tray
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
5000 pages
Print server - Ethernet, Fast Ethernet - integrated
AC 230V
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9, Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition
Microsoft Certification
Certified for Windows Vista
3 years warranty with product registration
43.5 cm x 60.4 cm x 34 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN
1200 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
8 sec
First Print Out Time Colour
9 sec
Language Simulation
Fonts Included
136 x PostScript , 87 x PCL
Barcodes
UPC-A, UPC-B, ZIP
Media Handling
533 MHz
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Flash Memory
Flash Memory
16 GB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
64 g/m² - 250 g/m²
400 sheets
Media Feeders
1 x automatic - 300 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 250 g/m²
Max Media Capacity
1460 sheets
Output Trays Capacity
350 sheets
Duty Cycle
75000 pages
5000 pages
Print server - integrated
Network / Transport Protocol
TCP/IP, UDP/IP, NetBEUI/NetBIOS, ICMP/IP, LPR/LPD, ARP, SMTP, FTP, BOOTP, DHCP, DNS, POP3, SMB
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, HTTP, NDPS, NDS
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x
Expansion Slots
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Supported Windows 7 Features
Windows HD Imaging
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
600 Watt
Power Consumption Stand by / Sleep
1.2 Watt
Software Included
OKI LPR, OKI Print Control Client, OKI Print Control Server, OKI PrintSuperVision.net, OKI Swatch Utility, OKI Web Driver Installer, OKI Gamma Utility, OKI Profile Assistant, OKI Storage Device Manager, OKI Color Correct, OKI Template Manager, OKI Color Access Policy Manager
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
54 dBA
43.5 cm
60.4 cm
34 cm
29 kg
Other bundles
£341.65
Save on TP Link Smart Plug
Save £2.00
£365.62
Scroll to top
