BT.com
Wishlist
OKI C332dn-2AC A4 Colour Laser Printer
OKI C332dn-2AC A4 Colour Laser...
£110.40
More than 50 in stock
£110.40
Add to wishlist
Delivery
Standard 1-3 working days
The C332dn brings professional HD quality color printing to the desktop for small workgroups at an affordable cost.
Key features
Flexible media handling and high quality output, combined with large memory for graphics-rich documents, makes the C332dn ideal for fast, in-house printing of marketing collateral and other color documents. Print on banners up to 52" in length without delay thanks to 1GB of internal RAM. And, meet everyday printing needs with many new advanced features packed into a sleek, small footprint.
Energy and cost savings
LED printing means fewer moving parts with more reliability and a longer lifespan for your C332dn. A toner saving mode, as well as Deep Sleep and Auto-Off modes conserve energy and reduce consumable costs.
Advanced Connectivity
Print from smartphones and tablets with Apple AirPrint™, Google Cloud Print 2.0 or the OKI Mobile Print Application. Easily transfer large color files across the network with Gigabit Ethernet, especially with the addition of the optional high-speed wireless LAN module. For simultaneous wired and wireless connections, the C332dn offers safe networking through Wireless Direct.
Simple to set up, use and own
Get started with the C332dn and its advanced features right out of the box, and stay updated on the newest features via the OKI Portal. In smaller offices, Duplex printing, combined with an optional second tray capable of boosting paper capacity to 880 sheets, makes for a powerful desktop solution at an affordable price. Switch to quiet mode for distraction-free printing of all your high-definition color graphics.
HIGHLIGHTS:
  • HD Color LED printing technology with multi-level output quality
  • Flexible media capabilities including up to 52" banners
  • 1 GB RAM memory ensuring trouble-free printing of graphics-intensive documents
  • Duplex printing standard
  • Generous paper capacity up to 880 sheets, with optional second tray
  • Google Cloud Print 2.0 and Apple AirPrint ready
  • 2 Year Standard Depot Warranty¹
OKI C332dn - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
22 kg
Media Size Class
A4
Print Speed
Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 26 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 600 dpi
Max Resolution (Colour)
1200 x 600 dpi
Automatic Duplexing
USB 2.0, LAN
RAM Installed (Max)
1 GB
Flash Memory Installed (Max)
3 GB
Barcodes
Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, ZIP
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet input tray
Monthly Duty Cycle (max)
45000 pages
Recommended Monthly Volume
5000 pages
Print server
AC 230V
Linux, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Microsoft Windows Vista / 7 / 8 / 8.1 / 10 (32/64 bits), Apple MacOS X 10.8.5 - 10.11
3 years warranty
41 cm x 50.4 cm x 24.2 cm
Printer Type
Printer
Print Speed
Wired
USB 2.0, LAN
1200 x 600 dpi
1200 x 600 dpi
Automatic Duplexing
Barcodes
Media Handling
RAM
RAM Installed (Max)
1 GB
Flash Memory
Flash Memory
3 GB
Media Handling
Media Size Class
A4
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm), B6 (125 x 176 mm), DL (210 x 99 mm)
Envelope Sizes
Com-10 (105 x 241 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
64 g/m² - 220 g/m²
350 sheets
Max Media Capacity
530 sheets
Output Trays Capacity
150 sheets
Duty Cycle
45000 pages
5000 pages
Print server
Security Protocols & Features
802.1x
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
540 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
52 dBA
41 cm
50.4 cm
24.2 cm
22 kg
Other bundles
£110.40
Save on TP Link Smart Plug
Save £2.00
£134.37
Scroll to top
