BT.com
Wishlist
OKI B840dn Mono Laser Printer
£1,101.04
Hurry, only 1 left in stock!
£1,101.04
Add to wishlist
Delivery
Standard 1-3 working days
Transform your black and white documents with the B840, the A3 printer with the speed, versatility and footprint of an A4 device. With sharper mono output, provided by OKI's innovative digital LED technology, the B840 brings A4 and A3 mono printing closer to your work group. Gone are the days of having to decipher your spreadsheets and diagrams with a magnifying glass. The B840 provides the convenience of fast desktop A4 printing speeds of up to 40 ppm with the capability to print your documents at a size that gives them and you a new perspective. The B840 brings affordable A4 and A3 mono printing to every business, large or small.
OKI B840dn - printer - monochrome - LED
Printer Type
Workgroup printer - LED - monochrome
28 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Min Media Size (Custom)
76 mm x 148 mm
Max Media Size (Custom)
297 mm x 431.8 mm
Print Speed
Up to 40 ppm - max speed - A4 (210 x 297 mm) , Up to 22 ppm - max speed - A3 (297 x 420 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
Parallel, USB, LAN
PowerPC 464FP H90 533 MHz
RAM Installed (Max)
128 MB (640 MB)
Language Simulation
PCL 5E, PostScript 3, EPSON FX, IBM PPR, SIDM
Barcodes
ZIP
Media Type
Envelopes, labels, plain paper
Total Media Capacity
630 sheets
Media Handling
100-sheet multipurpose tray, 530-sheet input tray
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
20000 pages
Print server - Ethernet, Fast Ethernet
AC 230V
Microsoft Windows Server 2008 R2, Apple MacOS X 10.3.9 - 10.6, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
Microsoft Certification
Compatible with Windows 7
3 years warranty with product registration
48.5 cm x 52.1 cm x 38.3 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
Parallel, USB, LAN
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
5 sec
Language Simulation
Fonts Included
87 x scalable PCL , 3 x bitmapped , 136 x scalable PostScript , 1 x barcode
Barcodes
ZIP
Media Handling
RAM
RAM Installed (Max)
128 MB / 640 MB (max)
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
76 mm x 148 mm
297 mm x 431.8 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), International C4 (229 x 324 mm), Com-9 (98 x 225 mm)
Media Weight
60 g/m² - 200 g/m²
630 sheets
Media Feeders
1 x automatic - 530 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 176 g/m² , 1 x automatic - 100 sheets - 297 x 432 mm weight: 60 g/m² - 200 g/m²
Max Media Capacity
1690 sheets
Output Trays Capacity
250 sheets
Duty Cycle
100000 pages
20000 pages
Print server
Network / Transport Protocol
TCP/IP, IPX/SPX, AppleTalk, NetBEUI/NetBIOS, ICMP/IP, LPR/LPD, ARP, SMTP, FTP, BOOTP, DHCP, DNS, POP3, RARP, Bonjour
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP
Security Protocols & Features
Apple Bonjour, TLS, IPsec, 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x parallel - 36 PIN Centronics , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
550 Watt
Power Consumption Stand by / Sleep
75 Watt
Software Included
OKI PrintSuperVision, OKI LPR, OKI Print Control Client, OKI Print Control Server, OKI Web Driver Installer, OKI Storage Device Manager, OKI Network Extension, OKI Template Manager, OKI PDF Print Direct
Environmental Standards
Green Tick Certified
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
54 dBA
48.5 cm
52.1 cm
38.3 cm
28 kg
Scroll to top
