BT.com
Wishlist
OKI B512dn Mono Laser Printer
£299.91
Hurry, only 1 left in stock!
£299.91
Add to wishlist
Delivery
Standard 1-3 working days
The B512dn black & white printer provides versatility, productivity and bottom-line savings for small workgroup environments.
If you're looking to improve the productivity and lower the operating costs of your business, the B512dn offers all of that and more.
For starters, the B512dn delivers up to 47 ppm, with the first page printing in as little as 4.5 seconds. It produces black & white output that's clear and crisp at up to 1200 x 1200 dpi resolution, using a two-piece consumables system for long-lasting performance and a low cost of operation.
The B512dn features a fast 667 MHz processor, as well as 3 GB of memory. It has a 630-sheet standard paper capacity (530-sheet main paper tray + 100-sheet multi-purpose tray) and can be outfitted with an optional 530-sheet 2nd paper tray, giving them a maximum capacity of 1,160 sheets - for longer uninterrupted productivity.
OKI B512dn - printer - monochrome - LED
Printer Type
Workgroup printer - LED - monochrome
13 kg
Media Size Class
A4/Legal
Max Media Size
210 x 1321 mm
Max Media Size (Custom)
210 mm x 1321 mm
Print Speed
Up to 45 ppm - B/W
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN
667 MHz
RAM Installed (Max)
512 MB
Flash Memory Installed (Max)
3 GB
Language Simulation
PCL 5E, PostScript 3, PCL 6, IBM ProPrinter, XPS, PDF 1.7
Barcodes
Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
Total Media Capacity
630 sheets
Media Handling
530-sheet input tray, 100-sheet bypass tray
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
750 - 5500 pages
Print server
AC 230V
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7 Lion, Apple MacOS X 10.6.8, Windows 8 (32/64 bits), Apple MacOS X 10.8, Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9, Microsoft Windows Server 2012 R2 x64 Edition
3 years warranty with product registration
28.6 cm x 38.7 cm x 39.4 cm
Printer Type
Printer
Print Speed
Up to 45 ppm - B/W
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
4.5 sec
Language Simulation
Fonts Included
87 x PCL , 136 x PostScript , 2 x bitmapped , 1 x barcode
Barcodes
Media Handling
667 MHz
RAM
RAM Installed (Max)
512 MB
Flash Memory
Flash Memory
3 GB
Media Handling
Media Size Class
A4/Legal
Max Media Size
210 x 1321 mm
210 mm x 1321 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
630 sheets
Media Feeders
1 x automatic - 100 sheets weight: 60 g/m² - 163 g/m² , 1 x automatic - 530 sheets weight: 60 g/m² - 105 g/m²
Max Media Capacity
1160 sheets
Duty Cycle
100000 pages
750 - 5500 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 3, IPP, HTTP, HTTPS, IPPS
Security Protocols & Features
IPsec
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
630 Watt
Power Consumption Stand by
80 Watt
Power Consumption Sleep
1.4 Watt
Limited warranty - 3 years
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
56 dBA
28.6 cm
38.7 cm
39.4 cm
13 kg
Scroll to top
