BT.com
Wishlist
OCZ Technology 750W Fatal1ty Series High-Performance PSU
Delivery
Standard Due date unavailable
High-Performance PSU / 750W / Low-Profile Modular Cable Management / 80-Plus Bronze Certified
Fatal1ty Series high-performance PSUs are co-developed to the high standards of Johnathan "Fatal1ty" Wendel, 12-time World champion to meet the specific needs of fellow gamers. Featuring new "low-profile" flat modular cabling, the Fatal1ty 750W PSU not only provides stable, efficient power, but also unique connectors that allow greater flexibility when organizing an internal case environment. Featuring glowing red LED lights to further personalize and add style to your system, Fatal1ty power supply products are ideal upgrades for users who need a computer setup able to take on hours of non-stop gaming.
The new Fatal1ty 750W features maximum and efficient power distribution, a thermally controlled 135mm double-ball bearing fan for airflow at near-silent audible noise levels, extremely tight and well regulated electrical noise and ripple, and an ideal array of connector types for multiple power-hungry drives and video cards. Offering excellent energy and cost savings, the Fatal1ty 750W garners a high efficiency rating with an 80-Plus® Bronze certification, converting up to a full 85% of AC to DC power at typical loads.
The Fatal1ty 750W Series is fully compliant with the latest ATX12V and EPS12V specifications to accommodate a wide range of cases, and comes backed by a 5-year warranty and tech support for additional peace of mind.
Note: Each and every OCZ modular power supply series uses dedicated modular cables that are specific to the power supply series. Use only the specific designed modular cables that comes packaged in the box.
  • 750W Continuous at 45°C
  • Maximum power distribution
  • Low-profile flat modular cabling
  • 150 x 160 x 86mm (W x L x H)
  • ATX12V v2.2 and EPS12V
  • Typical load 85% Efficiency
  • 80+ Bronze Certified
  • Overvoltage/OverPower/Short-Circuit protection
  • Premium Sag &Surge Protection (.98 PFC)
  • MTBF: 100,000 hours
  • 135mm double ball-bearing fan with red LED lighting
  • SLI™ Ready (Dual GPU)
  • 5 year warranty backed by OCZ's exclusive PowerSwap Warranty replacement program
Connectors
  • 1 x 20/24-pin ATX
  • 1 x 8-pin CPU
  • 1 x 4+4-pin CPU
Modular
  • 4 x 6+2-pin PCI-E
  • 6 x Peripheral
  • 2 x Floppy
  • 6 x SATA
OCZ Fatal1ty OCZ750FTY - power supply - 750 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.2/ EPS12V
80 PLUS Certification
80 PLUS Bronze
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Cooling System
135mm fan
15 cm x 16 cm x 8.6 cm
5 years warranty
ATX12V 2.2/ EPS12V
Input Voltage Range
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+3.3V - 28 A , +5V - 30 A , +12V1 - 18 A , +12V2 - 18 A , +12V3 - 18 A , +12V4 - 18 A , -12V - 0.8 A , +5VSB - 3 A
80 PLUS Bronze
Power cable
MTBF
100,000 hours
Cooling System
135mm fan
Over current protection, over voltage protection, short-circuit protection
Limited warranty - 5 years
15 cm
16 cm
8.6 cm
Scroll to top
