Click to visit BT.com
BT.com
Wishlist
OCZ Technology 512GB Vertex 4 M SATA 6Gb/s 2.5" Solid State Drive
Quicklinx: 88YFWS00
Mfr#: VTX4-25SAT3-512G.M
Essential accessories
Using quality Micron NAND flash, OCZ delivers the Vertex 4's highest capacity 512 GB model at an excellent cost savings for value-conscious upgraders. As the fourth generation of the legendary Vertex family, the Vertex 4 Series pushes storage performance to the max and redefines the modern day computing experience. Vertex 4 SSDs are innovatively engineered to deliver industry-leading file transfer rates and superior system responsiveness, all while providing a more durable, reliable, and energy efficient storage solution compared to traditional hard drives. Designed to take full advantage of the SATA III interface, the Vertex 4 unleashes ultimate productivity, gaming, and multimedia applications.
Mirroring real-world performance scenarios over a broad spectrum of consumer desktop and mobile applications, Vertex 4 SSDs are designed to provide a superior user experience and extreme performance over the other current solutions available on the market. With the Indilinx Everest 2 platform, Vertex 4 is optimized for consistent, high speeds with the complete spectrum of file types and sizes including both compressible and incompressible data for balanced performance like no other drive you've experienced.
OCZ Vertex 4 Series - solid state drive - 512 GB - SATA 6Gb/s
Solid state drive - internal
512 GB
NAND Flash Memory Type
20nm multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
1 GB
Native Command Queuing (NCQ), TRIM support, Indilinx Infused, synchronous flash memory, Indilinx Ndurance 2.0 Technology , S.M.A.R.T., 256-bit AES
6.963 cm x 9.98 cm x 0.93 cm
101 g
5 years warranty
512 GB
2.5"
SATA 6Gb/s
Buffer Size
1 GB
6.963 cm
9.98 cm
0.93 cm
101 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 510 MBps (write)
4KB Random Read
95000 IOPS
4KB Random Write
85000 IOPS
Maximum 4KB Random Write
120000 IOPS
Average Latency
0.02 ms
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x 2.5" - internal
Power Consumption
2.5 Watt ( active ) , 1.3 Watt ( idle )
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7, Microsoft Windows Vista / XP / 7 (64-bit versions)
3.5-inch bay adapter
FCC, RoHS, KCC
5 years warranty
Service & Support Details
Limited warranty - 5 years
70 °C
