BT.com
Wishlist
OCZ Technology 500W CoreXStream Series Power Supply
Delivery
Standard Due date unavailable
OCZ CoreXStream Series 500 Watt Power Supply
The OCZ CoreXStream Series is the ideal value upgrade to satisfy essential computing needs with worry-free compatibility. The PSU is kept supremely cool with a load-controlled 120mm fan to remain quiet under load, and provides ample cable lengths for your home system application. Featuring up to 80% efficiency under typical load environments, this power supply remains rock solid and stable under pressure. Combined with a sleek look and elegant black powdercoat finish, you can be rest assured this PSU will look as good as it performs in your home office system.
  • Ideal value option for home users and upgraders on a budget
  • Ample cable lengths to suit various applications and system configurations
  • Continuous output rated at 30°C ambient temperature
  • 80% efficient at typical loads
  • Dual +12V rails for efficient power distribution in your system.
  • Compliant with ATX12V v2.2 standard for worry-free compatibility
  • A temperature and load controlled 120mm fan for whisper quiet operation
  • ErP compliant for low power usage in standby
  • Active Power Factor Correction (PFC) to effectively regulate input voltage
  • Heavy-duty protection circuitry, (over-voltage, over-power, and short circuit) for protecting your valuable components
  • Safety Approvals: CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick
  • Elegant black powdercoat finish for a sleek and simple look
  • 3-Year OCZ PowerSwap Warranty, no endless return-for-repair loops
Connectors
  • 1 x 20+4-pin ATX
  • 1 x 4+4-pin ESP/12V CPU
  • 1 x 6+2-pin PCI-E
  • 1 x 6 pin PCI-E
  • 2 x 4-pin Peripheral
  • 4 x 5-pin SATA
  • 1 x FDD
  • AC Input 230Vrms, 5A, 50Hz
  • Output Voltage +3.3V +5V +12V1 +12V2 -12V +5VSB
  • Max. Load 24A 15A 25A 20A 0.3A 2.5A
  • Max. Combined 120W 444W 3.6W 12.5W
  • Total Output 500W
  • Dimensions: 5.9"(W) x 3.4"(H) X 5.5"(L); 150mm(W) x 86mm(H) x 140mm(L)
  • MTBF: 100,000 Hours
OCZ CoreXStream - power supply - 500 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.2
1.6 kg
United Kingdom
Input Voltage
AC 230 V
Power Capacity
500 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x 8 pin PCI Express power with detachable 2 pin section , 1 x 6 pin PCI Express power , 2 x 4 PIN internal power , 4 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
3 years warranty
ATX12V 2.2
United Kingdom
Input Voltage
AC 230 V
Frequency Required
50 Hz
Max Electric Current
5 A
Power Capacity
500 Watt
Circuit Protection
Circuit breaker
Output Current
+3.3V - 24 A , +5V - 15 A , +12V1 - 25 A , +12V2 - 20 A , -12V - 0.3 A , +5VSB - 2.5 A
Efficiency
80%
MTBF
100,000 hours
Cooling System
120 mm fan
Over voltage protection, overpower protection, dual 12V rails, short-circuit protection
FCC Class B certified, TUV, C-Tick, cUL, CB, CCC, ErP Ready
3 years warranty
Service & Support Details
Limited warranty - 3 years
15 cm
14 cm
8.6 cm
1.6 kg
Shipping Width
15.8 cm
Shipping Depth
18.7 cm
Shipping Height
16.5 cm
Shipping Weight
1.8 kg
Resources
The following resources are available for the OCZ Technology 500W CoreXStream Series Power Supply
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great price for a quality product.
Reviewed by Anonymous on 27/09/2012
If you switch the PSU off (at the switch on the back) you will find it uses in the region of 10w of electricity when your computer is not powered on. The PC iself differs in current draw per setup. I find the twin 6 pin PCI-e a very great bonus since its sometimes hard to find quality adapters.. that one of them doubles as an 8 pin only adds to the compatibility with many graphics cards. A great buy.
4* Seems Cheap
Reviewed by Ibrihim on 13/07/2013
Powering an i3 cpu 2 h/drives Gtx660 dvd and still giving enough to power some external usb devices.I can't find any reviews and it is low cost so took a gamble and so far 10 days heavy use and all OK. Three year G/tee is reassuring.
4* Good PSU be careful in large case with PSU at bottom
Reviewed by Keith Cross on 06/08/2013
Great PSU generally and great value.It has all the right connections for most uses (Graphics cards even Floppy for latest sound cards). However, if using in a large case with the PSU in the bottom, the CPU power lead only just reaches if you route the cables through the gap in PCI cards. Shame it doesn't have leads as long as Zalman ZM500-GT which seems perfect fr every scenario.
4* Powerful and quiet.
Everything on the specifications page appears to be accurate, this PSU powers a quad core with an GTX295 (which is quite the power hog being SLI in one card)in my PC.
Everything seems to run good, I only write this review to point out that if you do buy this PSU, you would be well advised to switch it of at the mains on a night, since to my surprise it uses 10 more watts when the computer is powered off than my old 500w psu which has lower amp ratings on the 12v rail (single rail)... It measures 25w draw here with nothing happeneing. (very surprised, since I expected more overall efficiency).
4* Good for the price and very quiet
Reviewed by Piculin on 28/02/2013
I'm using this with an i3 3220 and Radeon HD 7850.
Both are not large consumers so they would work even with a less powerful power supply.
I agree with everything what other reviews on this website say.
I'm not sure though how it would perform with more load,but for more configuration it works perfectly and it was the cheapest option.
Also,it is very quiet. You can barely hear it and it is in general less noisy than an average 120mm fan.
When there isn't much load the fan even turns off.
I have no idea about its efficiency,but I don't bother with that because power bills are included in my rent :D
Overall,good for price,but I haven't read many other reviews so I can't say whether it would work with actual 500W gaming rig.
main advantages
-cheap
-quiet
Scroll to top
