BT.com
Wishlist
OCZ Technology 256GB Vertex 4 SATA 6Gb/s 2.5" Solid State Drive
Delivery
Standard Due date unavailable
Our Vertex 4 series, the fastest SSD available on the market, just became even faster with our latest 1.5 firmware release. The higher capacity drives have a significant increase on sequential writes which now reaches up to 510MB/s.
Rethink Storage Performance & Endurance
As the fourth generation of the legendary Vertex family, the Vertex 4 Series pushes storage performance to the max and redefines the modern day computing experience. Vertex 4 SSDs are innovatively engineered to deliver industry-leading file transfer rates and superior system responsiveness, all while providing a more durable, reliable, and energy efficient storage solution compared to traditional hard drives. Designed to take full advantage of the SATA III interface, the Vertex 4 unleashes ultimate productivity, gaming, and multimedia applications.
Excelling in Performance, No Matter the File Type
Mirroring real-world performance scenarios over a broad spectrum of consumer desktop and mobile applications, Vertex 4 SSDs are designed to provide a superior user experience and extreme performance over the other current solutions available on the market. With the cutting-edge Indilinx Everest 2 platform, Vertex 4 is optimized for consistent, high speeds with the complete spectrum of file types and sizes including both compressible and incompressible data for balanced performance like no other drive you've experienced.
Industry's Highest I/O Performance
Incredible performance at up to 120,000 IOPS in workstation and heavy-duty environments with multiple data threads
No Compression-Related Limitations
Better performance with "real world" data streams of varying "compressibility" as well as fully incompressible data such as videos and multimedia files, encrypted data, archive files such as .ZIP files and software.
Indilinx Infused™ Everest 2 Platform
Leading edge dual-ARM controller architecture enables faster performance like nothing else you've experienced.
Industry-Low Latency and Boot Ups
Boot up in as little as 9 seconds, and experience latencies of 0.02ms enabling superior responsiveness and data access.
Ndurance 2.0 Technology
Sophisticated advanced suite of NAND Flash management increases durability and reliability to expand the NAND's lifespan.
Industry-Leading Warranty
Limited 5 year warranty backed by OCZ's renowned service for ultimate peace of mind.
Industry Leading Performance
  • High Performance SATA 6Gbps
  • Best-in-Class Indilinx Controller Technology
  • Up to 560 MB/s Sequential Reads
  • Up to 95,000 Random Write IOPS
  • Up to 120,000 Maximum IOPS
  • Available in 128GB to 512GB Capacities
  • Access Latency as Low as 0.02ms
  • Strong performance at Lower Queue Depths
  • TRIM Support
  • 3.5" Desktop Adaptor Bracket Included
256GB Specifications
  • Max Read: up to 560 MB/s (with latest Firmware)
  • Max Write: up to 510 MB/s (with latest Firmware)
  • Max 4KB Random Read: 90,000 IOPS
  • Max 4KB Random Write: 85,000 IOPS
  • Maximum IOPS: 120,000 IOPS
Range Specifications
  • Usable Capacities (IDEMA): 128GB, 256GB, 512GB
  • NAND Components: 2Xnm Synchronous Multi-Level Cell (MLC)
  • Interface: SATA III / 6Gbps (backwards compatible with SATA II / 3Gbps)
  • Form Factor: 2.5 Inch
  • NAND Controller: Indilinx Everest 2
  • DRAM Cache: Up to 1GB
  • Dimensions (L x W x H): 99.8 x 69.63 x 9.3 mm
  • Weight: 101g
  • MTBF: 2 million hours
  • Data Path Protection: ECC engine corrects up to 128 random bits/1KB
  • Data Encryption: 256-bit AES-compliant, ATA Security Mode Features
  • Product Health Monitoring: Self-Monitoring, Analysis and Reporting Technology (SMART) Support
  • Flash Endurance Management: Indilinx Ndurance™ 2.0 Technology
  • Power Consumption: Idle: 1.3 W Active: 2.5 W
  • Operating Temperature: 0°C ~ 70°C
  • Ambient Temperature: 0°C ~ 55°C
  • Storage Temperature: -45°C ~ 85°C
  • Shock Resistance: 1500G
  • Certifications: RoHS, CE, FCC, KCC
  • Serial ATA (SATA: Fully compliant with Serial ATA International Organization: Serial ATA Revision 3.0. Fully compliant with ATA/ATAPI-8 Standard Native Command Queuing (NCQ)
  • Operating System: Windows XP 32-bit /64-bit, Windows Vista 32-bit / 64-bit, Windows 7 32-bit / 64-bit, Linux; Mac OS X
  • Power Requirements: Standard SATA Power Connector
Performance Optimization
  • TRIM (requires OS support), dynamic and static wear-leveling, background garbage collection
  • Other Performance Features: Ndurance 2.0 Technology (Reduced Write Amplification without Compression, Advanced Multi-Level ECC, Adaptive NAND Flash Management)
  • Service & Support: Limited 5-Year Warranty, Toll-Free Tech Support, 24 Hour Forum Support
See The OCZ Vertex 4 Solid State Drives In Action!
OCZ Vertex 4 Series - solid state drive - 256 GB - SATA 6Gb/s
Solid state drive - internal
256 GB
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H (in 3.5" carrier)
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), Background Garbage Collection, TRIM support, Dynamic and Static Wear Leveling, Indilinx Ndurance 2.0 Technology , S.M.A.R.T., 256-bit AES, 128/1K bit BCH ECC
70 mm x 100 mm x 9 mm
101 g
5 years warranty
256 GB
256-bit AES
2.5" x 1/8H
SATA 6Gb/s
70 mm
100 mm
9 mm
101 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 510 MBps (write)
4KB Random Read
90000 IOPS
4KB Random Write
85000 IOPS
Maximum 4KB Random Write
120000 IOPS
Reliability
MTBF
2,000,000 hour(s)
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H or 3.5" (with included bay adapter)
Power Consumption
2.5 Watt ( active ) , 1.3 Watt ( idle )
Apple MacOS, Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
3.5-inch bay adapter
FCC, RoHS, KCC
Limited warranty - 5 years
70 °C
Resources
The following resources are available for the OCZ Technology 256GB Vertex 4 SATA 6Gb/s 2.5" Solid State Drive
Scroll to top
