Click to visit BT.com
BT.com
Wishlist
OCZ Technology 240GB Vertex 3 Series SATA III 2.5" Solid State Drive
Quicklinx: 7D7YWS00
Mfr#: VTX3-25SAT3-240G
Essential accessories
Delivering double the performance of the previous generation...
As the third generation of the legendary Vertex Series, OCZ Vertex 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives.
In addition to maximized productivity, a Vertex 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption. Using the latest breakthrough controller and flash technology, Vertex 3 SSDs work in perfect harmony with next generation platforms and operating systems to deliver the industry's best storage solution.
Specification
  • NAND Components: 2Xnm Multi-Level Cell (MLC)
  • Interface: SATA III / 6Gbps (Backwards compatible with SATA II / 3Gbps)
  • Form Factor: 2.5 Inch
  • Controller: SandForce®2281
  • Dimensions(L x W x H): 99.8 x 69.63 x 9.3mm
  • Seek Time: 0.1 ms
  • Weight: 77g
  • Power Consumption: Idle: 1.65 Watts Active: 3 Watts
  • Operating Temperature: 0°C ~ +55°C
  • Storage Temperature: -45°C ~ +85°C
  • ShockResistance: 1500G
  • Certifications: RoHS, CE, FCC
  • MTBF: 2 millionhours
  • ECC Recovery: Up to 16 bytes correctable per 512-byte sector
  • Product Health Monitoring: Self-Monitoring, Analysis and ReportingTechnology (S.M.A.R.T.)
  • SerialATA (SATA): Fully compliant with Serial ATA InternationalOrganization: Serial ATA Revision 3.0.Fully compliant with ATA/ATAPI-8StandardNative Command Queuing (NCQ)
  • Operating System: Windows XP 32-Bitand 64-Bit;Windows Vista 32-Bitand 64-Bit;Windows 7 32-Bitand64-Bit
  • Power Requirements: Standard SATA Power Connecto
  • Performance Optimization: TRIM (requires OSsupport)
  • System Integration: Bundled with 3.5" desktop adapter bracket:
  • Service & Support: 3-Year Warranty, Toll-Free Tech Support, 24 Hour Forum Support, Firmware Updates
See The OCZ Vertex 3 Solid State Drives In Action!
OCZ Vertex 3 Series - solid state drive - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), TRIM support , S.M.A.R.T.
100 mm x 70 mm x 9.3 mm
77 g
3 years warranty
240 GB
2.5" x 1/8H
SATA 6Gb/s
100 mm
70 mm
9.3 mm
77 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
4KB Random Read
40000 IOPS
4KB Random Write
60000 IOPS
Maximum 4KB Random Write
85000 IOPS
Seek Time
0.1 ms (average)
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x 2.5" x 1/8H - internal
Power Consumption
3 Watt ( active )
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
3.5-inch bay adapter
FCC, RoHS
3 years warranty
Service & Support Details
Limited warranty - 3 years
55 °C
Resources
The following resources are available for the OCZ Technology 240GB Vertex 3 Series SATA III 2.5" Solid State Drive
