BT.com
Wishlist
OCZ Technology 1250W Max Performance Modular PSU
Free delivery
Delivery
Standard Due date unavailable
The ZX series is the unsurpassed solution for driving today's Enthusiast and gaming systems. It has the ability to easily power both NVIDIA SLI and ATI CrossFire modes, supporting even the most power hungry GPUs with up to triple GPU configurations. Industrial-grade yet designed with enthusiasts, gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and the most compact form factor of its class.
Kept ultra-cool with a load-controlled ultra quiet 140 mm fan, the ZX Series was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 92% efficiency at typical load and up to 89% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load. The OCZ ZX series provides universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power.
OCZ ZX Series 1250W - power supply - 1250 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.2/ EPS12V
80 PLUS Certification
80 PLUS Gold
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1250 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 12 x 15 pin Serial ATA power , 9 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
140 mm fan
15 cm x 17.5 cm x 8.6 cm
5 years warranty
ATX12V 2.2/ EPS12V
Input Voltage Range
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1250 Watt
Output Current
+3.3V - 30 A , +5V - 30 A , +12V1 - 104 A , -12V - 0.6 A , +5VSB - 3 A
80 PLUS Gold
MTBF
100,000 hours
Cooling System
140 mm fan
Over current protection, over voltage protection, SLI ready, CrossFire ready, short-circuit protection, single 12V rail, ball bearing cooling fan
5 years warranty
Service & Support Details
Limited warranty - 5 years
15 cm
17.5 cm
8.6 cm
Scroll to top
