BT.com
Wishlist
OCZ PSU, ModXStream Pro, 600W - UK
Delivery
Standard Due date unavailable
The ModXStream Pro Series is the superlative solution for driving today's gaming systems, and is NVIDIA SLI certified to power dual graphics. Professional-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 135mm fan, the ModXStream Pro was engineered to be the quietest PSU available and eliminate distracting noises from your PC. 80+ Certified, featuring up to 86% efficiency at typical load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
As a gamer or case modder, modular cabling is a necessity when building a cool and orderly system. To optimize airflow and eliminate cable mazes, the ModXStream Pro is equipped with "EZMod" Technology to allow complete customization of your power system by utilizing only the cables you require. The OCZ ModXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power.
OCZ ModXStream Pro - power supply - 600 Watt
Power supply - active Power Factor Correction (PFC) - internal
Output Connectors
4 PIN internal power, 4 PIN mini-power connector, power 4 pin ATX12V connector, 15 pin Serial ATA power, power 8 pin +12V, 6 pin PCI Express power, power 24 pin ATX with detachable 4 pin section, 8 pin PCI Express power with detachable 2 pin section
Specification Compliance
ATX12V 2.2/ EPS12V
United Kingdom
Output Voltage
+3.3, +5, ±12 V
Power Capacity
600 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V , 1 x power 4 pin ATX12V connector , 1 x 6 pin PCI Express power , 1 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 2 x 4 PIN mini-power connector , 6 x 15 pin Serial ATA power
15 cm x 16 cm x 8.6 cm
3 years warranty
ATX12V 2.2/ EPS12V
Output Connectors
United Kingdom
Input Voltage Range
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
600 Watt
Output Current
+5V - 25 A , +3.3V - 25 A , +12V1 - 25 A , +12V2 - 25 A , -12V - 0.3 A , +5VSB - 2.5 A
MTBF
100,000 hours
Active Power Factor Correction (PFC), over voltage protection, overpower protection, SLI ready, CrossFire ready, cable management, short-circuit protection
Limited warranty - replacement - 3 years
15 cm
16 cm
8.6 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* modular= awesome!!
Reviewed by Charlie Booker on 03/02/2012
i am using this in conjunction with an Asrock extreme 4 870 am3+ mobo and a Sharkoon t9 green. It works great it's powering the motherboard my phenom ii x4 960t overclocked to 3.5ghz, and my XFX 6770.
The only reason it did not get a 5 out of 5 for ease of use was because the cables COULD be longer i have a bottom mounting power supply and have had to go and buy a 8 pin extension so i can use the cable management on the case.
sleeves are good , the product feels well made and durable.
none modular cables are : 20 + 4 pin, 8 pin and 4 pin which i have tucked in behind the motherboard tray because it is not needed.
Scroll to top
