BT.com
Wishlist
OCZ PSU, ModXStream Pro, 500W - UK
Delivery
Standard Due date unavailable
The ModXStream Pro Series is the superlative solution for driving today's gaming systems, and is NVIDIA SLI certified to power dual graphics. Professional-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 135mm fan, the ModXStream Pro was engineered to be the quietest PSU available and eliminate distracting noises from your PC. 80+ Certified, featuring up to 86% efficiency at typical load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load. As a gamer or case modder, modular cabling is a necessity when building a cool and orderly system. The OCZ ModXStream provides universal input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power.
OCZ ModXStream Pro - power supply - 500 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.2/ EPS12V
United Kingdom
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V , 1 x power 4 pin ATX12V connector , 1 x 6 pin PCI Express power , 1 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 2 x 4 PIN mini-power connector , 6 x 15 pin Serial ATA power
15 cm x 16 cm x 8.6 cm
3 years warranty
ATX12V 2.2/ EPS12V
United Kingdom
Input Voltage Range
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output Current
+5V - 25 A , +3.3V - 25 A , +12V1 - 18 A , +12V2 - 18 A , -12V - 0.3 A , +5VSB - 2.5 A
MTBF
100,000 hours
Active Power Factor Correction (PFC), over voltage protection, overpower protection, SLI ready, CrossFire ready, cable management, short-circuit protection
Limited warranty - replacement - 3 years
15 cm
16 cm
8.6 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Brilliant mid-spec PSU
Reviewed by Paul M on 20/12/2012
I wanted an 80+ PSU, and this gave a good balance between power and cost. It runs very quietly, and the removable power cables (for devices you don't need) mean the case has minimal clutter. The included cables are long enough to reach wherever I need them to.
Very happy with this purchase - recommended.
Scroll to top
