BT.com
Wishlist
NVIDIA Quadro M2000 - Graphics card - Quadro M2000 - 4 GB GD
NVIDIA Quadro M2000 - Graphics card...
£502.78
Hurry, only 3 left in stock!
£502.78
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Get fast performance and work interactively with models and scenes across CAD, DCC, and medical applications with the new Maxwell GPU architecture features of the flexible, single-slot NVIDIA Quadro M2000 graphics card.
Experience ultra-fast visualization and compute horsepower with 4GB ultra-fast GDDR5 memory and CUDA® parallel processing.
Drive up to four 4K or two 5k displays or one 8K projector with four DisplayPort 1.2 ports and managed them with included NVIDIA® Mosaic™ and NVIDIA® nView® technologies. Enable immersive collaboration with optional 3D Vision™ and 3D Vision Pro.
Boost application performance in real time while staying within the power and thermal envelope of the card with NVIDIA® GPU Boost.
Easily support your professional software application base with comprehensive ISV certifications.
Compatible with Z240 CMT, Z440, Z640, Z840.
NVIDIA Quadro M2000 - graphics card - Quadro M2000 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M2000
4 GB GDDR5
CUDA Cores
768
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
DisplayPort: 4096 x 2160 at 60 Hz / DisplayPort: 2560 x 1600 at 120 Hz
Max Monitors Supported
4
4 x DisplayPort (HDCP)
API Supported
OpenCL, DirectCompute 5.0, DirectX 12, OpenGL 4.5
16.7 cm x 11 cm
Pricing Type
Promo
Workstation Z240 (MT, tower), Z440, Z640, Z840
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M2000
CUDA Cores
768
Max Resolution
4
API Supported
Nvidia CUDA technology, NVIDIA Mosaic, NVIDIA GPU Boost, Multi-Stream Technology, Maxwell architecture, HDCP
Size
4 GB
GDDR5 SDRAM
Bus Width
128-bit
Bandwidth
105.7 GBps
Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
75 Watt
16.7 cm
11 cm
230 g
Pricing Type
Promo
HP Workstation Z240 (MT, tower), Z440, Z640, Z840
Scroll to top
