BT.com
Wishlist
NVIDIA Quadro K4000 3GB Graphics Card
Delivery
Standard Due date unavailable
The NVIDIA Quadro K4000 graphics board is a single slot PCI Express add-in card based on the new NVIDIA Kepler architecture graphics processing unit (GPU). The Quadro K4000 graphics board is the perfect choice for medium-to-large complexity designs and models in professional CAD, M&E and visualization applications. This card provides impressive performance capabilties in a single slot design.
NVIDIA Quadro K4000 graphics card - Quadro K4000 - 3 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K4000
3 GB GDDR5
RAMDAC
400 MHz
Memory Interface
192-bit
Max Resolution
3840 x 2160
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 3840 x 2160
Max Monitors Supported
4
2 x DisplayPort , DVI-I (dual link)
API Supported
DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.3
24.13 cm x 11.11 cm
Workstation Z220 (CMT), Z230 (MT), Z420, Z620, Z820
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K4000
RAMDAC
400 MHz
Max Resolution
3840 x 2160 at 60 Hz
4
API Supported
Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Shader Model 5.0, Kepler GPU Architecture, Nvidia Quadro Mosaic Technology
Size
3 GB
GDDR5 SDRAM
Bus Width
192-bit
Bandwidth
134 GBps
Red Hat Enterprise Linux Desktop 5, SUSE Linux Enterprise Desktop 11, Microsoft Windows 7 Professional (32/64 bits), Red Hat Enterprise Linux Desktop 6, Windows 8 Pro 64-bit Edition
80 Watt
1 x DisplayPort-DVI adapter
24.13 cm
11.11 cm
HP Workstation Z220 (CMT), Z230 (MT), Z420, Z620, Z820
Scroll to top
