Click to visit BT.com
BT.com
Wishlist
Nurvo Android ICS HDMI TV Stick
Huge Saving - Was £34.98!
2.0*
Quicklinx: 89PBWS00
Mfr#: Nurvo-01
Make any HDMI TV a Smart TV!
Click here for Optional Remote/Keyboard
This tiny stick plugs into a HDMI socket on your TV, power is fed in from a USB socket on your TV, or from a mains powered adapter.
The Stick runs Android 4 (Ice Cream Sandwich) and has access to the Android Play Store, to install a staggering array of applications.
Mini Google TV Box Stick Feature:
CORTEX-A5 1GHZ TCC89252
Android 4.0,Full HD(1080P)
WI-FI, USB
HD video decoder(1080P@60Fps), HD video encoder(1080P@30Fps)
HDMI 1.4
WIFI to internet - with WIFI, you can easily surf internet, enjoy all internet sources
External Memory - Connect U flash,HDD or SD per USB interface.
Simple Operation:Support Remote control and Mouse operation.
OS: Android4.0(Later)
Linux: Kernel 2.6.35.7+3.
Language Support: Multi Languages
Input Method1: Android Keyboard5. Input Method2: 2.4G Mouse
Wireless Network
WiFi IEEE: 802.11 b/g/n(AR6103)
WIFI Mobile DISPLAY: Support wifi connect with Mobile display
DC-IN USE Micro USB4. USB Socket: Micro USB(OTG)&USB-4P (HOST)
2.4G wireless mouse Support and 2.4G wireless keyboard Support
DLNA: DIGITAL LIVING NETWORK ALLIANCE7
WPS: Wireless Provisioning Services
Audio Music: Player(MP3/WMA/WAV/OGG/AAC/FLAC/3GP...)
Video Movie: Player(MPEG2/4/AVI/WMV/MKV/MOV/RM/RMVB...)
Picture Viewer: Gallery
Web Browser: Browser5. Game of Android: APK of Android
Pre-Load Applications
Adobe Flash Player: V11.1 or Later
HTML5: Support
Files Manager: R.E. Manager
Online stream playback: Youtube & YOUKU5.
TXT editor: IREAD
1. Length: 82mm2. Width: 26.5mm3. Height: 13.8mm(Max)4. Weight(g): About 30g
Header / Manufacturer
Nurvo
Digital audio playback, Digital photo playback, Digital video playback, Internet video playback, WEB browsing, YouTube videos playback
Digital Multimedia Devices / Key Features
Digital audio player, Digital photo viewer, Digital video player
Digital Multimedia Devices / TV Output Resolution
1080P
Digital Audio / Supported Audio Formats
AAC, FLAC, MP3, Ogg Vorbis, WAV, WMA
Playback Format
AVI, MKV, MOV, MPEG-2, MPEG-4, RMVB, WMV
Still Images / Supported Still Images Formats
BMP, GIF, JPEG, PNG
Digital Multimedia Devices / Device Type
Digital AV player
Connectivity / Connectivity Type
HDMI output
IEEE 802.11b (Wi-Fi), IEEE 802.11g, IEEE 802.11n, USB
Remote Control / Type
None
Miscellaneous / Colour
White
Networking / Connectivity Technology
Wireless
Network & Internet Multimedia / DLNA
Dimensions & Weight / Depth
82 mm
Dimensions & Weight / Height
13.8 mm
Dimensions & Weight / Width
26.5 mm
Dimensions & Weight / Weight
30 g
Nurvo
Digital AV player
Playback Format
HDMI output
1080P
Wireless
White
Remote Control / Technology
Radio
BMP, GIF, JPEG, PNG
Audio Formats
82 mm
30 g
26.5 mm
13.8 mm
Customer reviews
Write a review for the Nurvo Android ICS HDMI TV Stick here!
Terrible DO NOT USE FOR HD CONTENT
Reviewed by Tony. Review Posted 23/12/2012
underpowered, raw ics with features removed, not true hd (is 720 stretched into a 1080 output signal) can't even play local (usb) 1080.mkv well. default apps are crude, undeveloped and some of them are in Chinese. xbmc, launcher version, (The ideal solution for devices of this type) fails.. though also does on a high end tablets. The built in 2.4g transceiver mentioned in the add does not exist. mouse and/or keyboard support is.. iffy (I'm sure this would work better if you buy the remote)
Nice idea just badly implemented.
  • Overall 2*
  • Ease of use 3*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
