BT.com
Wishlist
Noctua NH-U12DO A3 AMD Opteron CPU Cooler
Delivery
Standard Due date unavailable
Noctua's DO line of coolers has become a default choice when it comes to quietly cooling AMD Opteron CPUs. Upgrading both compatibility and performance, the A3 model features Noctua's professional NM-A3 SecuFirm2 mounting system that not only supports socket G34, C32 and F, but also allows to install the cooler turned by 90°. Thanks to six heatpipes, a performance optimized fin stack and its two premium grade NF-P12 120 mm fans, the NH-U12DO A3 cools even the hottest high-end Opteron processors at minimum noise levels. Bundled with Noctua's industrial-grade NT-H1 thermal compound, the NH-U12DO A3 forms a complete premium quality package for quietly cooling AMD workstations and servers.
Noctua NH-U12DO A3 - processor cooler
Processor cooler
Package Content
Thermal paste, Ultra-Low-Noise Adaptor (U.L.N.A.), Low-Noise Adaptor (L.N.A.), SecuFirm2 Mounting Kit
Compatibility
Socket F, Socket G34, Socket C32
Heatsink Material
Aluminum with nickel plated copper base
Fans Qty
Dual
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
SSO bearing
Rotation Speed
900/1100/1300 rpm
Air Flow
63.4/78.5/92.3 cfm
Noise Level
12.6/16.9 /19.8 dBA
Rated Voltage
12 V
6 nickel plated copper heat pipes
12.6 cm x 12 cm x 15.8 cm
1.14 kg
6 years warranty
Processor cooler
Package Content
12.6 cm
12 cm
15.8 cm
1.14 kg
Heatsink & Fan
Compatible With
Processor Compatibility
Opteron
Heatsink Material
Heatsink Dimensions
158 mm x 126 mm x 71 mm
Fans Qty
2
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
SSO bearing
Rotation Speed
900/1100/1300 rpm
Air Flow
63.4/78.5/92.3 cfm
Noise Level
12.6/16.9 /19.8 dBA
Noise & Performance Details
19.8 dBA / 92.3 cfm at 1300 rpm , 16.9 dBA / 78.5 cfm at 1100 rpm , 12.6 dBA / 63.4 cfm at 900 rpm
Rated Voltage
12 V
Power Consumption
1.08 W
Mounting Kit
Included
MTBF
150,000 hour(s)
6 years warranty
Service & Support Details
Limited warranty - 6 years
Scroll to top
