BT.com
Wishlist
Noctua NH-D15 Dual Radiator Quiet CPU Cooler with two NH-A15 Fans
Noctua NH-D15 Dual Radiator Quiet...
£84.22
£84.22
Add to wishlist
Delivery
Standard Due date unavailable
The new king of air coolers has arrived. Noctua's new NH-D15 features two NF-A15 fans and a massive six year warranty.
Built on the basis of the legendary NH-D14 and carrying on its quest for ultimate quiet cooling performance, Noctua's flagship model NH-D15 is an elite-class dual tower cooler for the highest demands. Its expanded heatpipe layout and two premium grade NF-A15 140mm fans with PWM support for automatic speed control allow it to further improve the NH-D14's award-winning efficiency. Topped off with the trusted, pro-grade SecuFirm2 multi-socket mounting system, Noctua's proven NT-H1 thermal compound and full six years manufacturer's warranty, the NH-D15 forms a complete premium quality solution that represents a deluxe choice for overclockers and silent-enthusiasts alike.
  • Based on the award-winning NH-D14
  • Widened fin stack and expanded heatpipe layout
  • Dual NF-A15 140mm fans
  • SecuFirm2 mounting system
  • Compatible with Intel LGA2011/1155/1156/1150 and AMD FM1/FM2/AM3+/AM3/AM2+/AM2
Noctua's NH-D14 has received more than 350 awards and recommendations from leading international hardware websites and magazines, making it one of the most successful premium heatsinks ever built. With its expanded layout and dual NF-A15 fans, the NH-D15 further improves the D14's much acclaimed quiet cooling performance.
Six heatpipe dual tower design
As compared to conventional single tower heatsinks, the NH-D15's fine-tuned six heatpipe dual tower design provides more surface area, better heat-distribution and superior airflow efficiency in dual fan mode.
Compared to the NH-D14, the NH-D15's fin-stack has been widened from 140 to 150mm and its heatpipes are now spaced further apart, which allows for a more uniform heat distribution over a larger surface area and thus contributes to the NH-D15's superior efficiency.
High RAM compatibility in single fan mode
Thanks to its recessed lower fins, the NH-D15 provides 64mm clearance for tall memory heatsinks in single fan mode, making it compatible with most high end RAM modules on the market. In dual fan mode, the NH-D15 should be used with standard height RAM (up to 32mm). Please note: In chassis with more than 165mm CPU cooler clearance, the front fan can be moved upwards to make room for memory modules taller than 32mm.
The NH-D15 features two of Noctua's premium class NF-A15 140mm fans. Complying with Noctua's AAO standard and featuring sophisticated aerodynamic design measures such as Flow Acceleration Channels, the NF-A15 has quickly built up a reputation as one of the best 140mm fans on the market.
PWM support and Low-Noise Adaptor
The NF-A15 premium fans supplied with the NH-D15 support PWM for convenient automatic speed control through the mainboard. In addition, the maximum fan speed can be reduced from 1500 to 1200rpm using the supplied Low-Noise Adaptor for even quieter operation.
Excellent component cooling
Extending below the fin-stacks, the large NF-A15 fans not only contribute to the NH-D15's superb CPU cooling capabilities but also provide massive airflow over surrounding motherboard components and heatsinks, thus ensuring excellent component cooling performance.
SecuFirm2 mounting system*
Noctua's SecuFirm2 mounting systems have become synonymous with quality, safety and ease of use. Supporting Intel LGA115x (LGA1150, LGA1155, LGA1156), LGA2011 and AMD (AM3(+), AM2(+), FM1, FM2(+)), the SecuFirm2 mounting included with the NH-D15 guarantees perfect contact pressure and maximum convenience on all current sockets.
Compatibility with past and future sockets
Complying with the open SecuFirm standard, the NH-D15 can be made compatible with the older LGA1366 and LGA775 sockets using the optional NM-I3 mounting kit, which is provided by Noctua free of charge. If technically possible, Noctua will also provide upgrade kits for future sockets.
Having received more than 100 awards and recommendations from hardware journalists around the world, Noctua's NT-H1 is a proven professional grade TIM solution that provides minimum thermal resistance, excellent ease of use and outstanding reliability.
Features six year warranty
Noctua products are renowned for their impeccable quality and outstanding longevity. Like all Noctua fans, the supplied NF-A15's feature an MTBF rating of more than 150.000 hours and the entire NH-D15 package comes with a full 6 years manufacturer's warranty.
  • Compatibility Intel LGA2011/1155/1156/1150 and
  • AMD FM1/FM2/AM3+/AM3/AM2+/AM2 (backplate required)
  • Max TDP All
  • Installation Method Intel and AMD - backplate, requires motherboard removal
  • Height (without fan) 165 mm
  • Width (without fan) 150 mm
  • Depth (without fan) 135 mm
  • Height (with fan) 165 mm
  • Width (with fan) 150 mm
  • Depth (with fan) 161 mm
  • Weight (without fan) 1000 g
  • Weight (with fans) 1320g
  • Material Copper (base and heat-pipes), aluminium (cooling fins), soldered joints & nickel plating
  • Fan compatibility 140x150x25, 140x140x25, 120x120x25 (with 120mm mounting holes)
  • Fan Model Two Noctua NF-A15
  • Fan Bearing SSO2-Bearing
  • Fan Rotational Speed (±10%) 1500 RPM
  • Fan Rotational Speed with L.N.A. (±10%) 1200 RPM
  • Min. Rotational Speed (PWM, ±20%) 300 RPM
  • Max. Airflow 82.5 CFM
  • Max. Airflow with L.N.A. 67.9 CFM
  • Max. Acoustical Noise 24.6 dB(A)
  • Max. Acoustical Noise with L.N.A. 19.2 dB(A)
  • Input Power 1.56 W
  • Voltage Range 12 V
  • MTBF > 150.000 h
  • Warranty 72 months
  • EAN barcode 4716123315360
Noctua NH-D15 - processor cooler
Processor cooler
Package Content
2 Low-Noise Adaptor (L.N.A.), Y-Split cable, SecuFirm2 Mounting Kit, metal case-badge, NT-H1 thermal paste, 2x NF-A15 PWM premium fan
Compatibility
LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA1151 Socket
Heatsink Material
Aluminium with copper base
Fans Qty
Dual
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
SSO2 bearing
Rotation Speed
300-1500 rpm
Air Flow
68-82.7 cfm
Noise Level
19.2 - 24.6 dBA
Power Connector
4-pin fan connector
Heat pipe technology, Pulse-width modulation (PWM) support, 6 copper heatpipes, Soldered joints
15 cm x 16.1 cm x 16.5 cm
1.32 kg
6 years warranty
Processor cooler
Package Content
15 cm
16.1 cm
16.5 cm
1.32 kg
Heatsink & Fan
Compatible With
Heatsink Material
Fans Qty
2
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
SSO2 bearing
Rotation Speed
300-1500 rpm
Air Flow
68-82.7 cfm
Air Pressure
1.51-2.08 mm
Noise Level
19.2 - 24.6 dBA
Noise & Performance Details
19.2 dBA / 68 cfm at 1200 rpm , 24.6 dBA / 82.7 cfm at 1500 rpm
Power Connector
4-pin fan connector
Start Voltage
12 V
Power Consumption
1.56 W
Mounting Kit
Included
MTBF
150,000 hour(s)
Limited warranty - 6 years
Noctua NH-D15 Dual Radiator Quiet CPU Cooler with two...
£84.22
Save on this ideal PC Build kit!
Save £8.29
£103.39
Scroll to top
