BT.com
Wishlist
Noctua NF-F12 PWM 120mm Focused Flow PWM Cooling Fan
Noctua NF-F12 PWM 120mm Focused...
£18.79
£18.79
Add to wishlist
Delivery
Standard Due date unavailable
Teaming up eleven stator guide vanes with a specially conceived seven blade impeller, the NF-F12's Focused Flow™ system creates outstanding static pressure and focuses the airflow for superior performance on heatsinks and radiators.
At the same time, a wide range of advanced aerodynamic design measures, second generation SSO-Bearings and Noctua's new, custom designed PWM IC for fully automatic control guarantee astounding quietness of operation. The NF-F12 comes with modular cabling, integrated anti-vibration pads and two speed settings for full flexibility. Its commanding performance, exhaustive set of features and Noctua's trusted premium quality make it an elite choice for use on air coolers, radiators and other pressure demanding applications.
Focused Flow Frame
Designed for pressure demanding applications such as heatsinks and radiators, the Focused Flow™ frame features eleven stator guide vanes that straighten, channel and focus the airflow, which allows the NF-F12 to rival the performance of conventional fans running at much faster speeds.
Varying Angular Distance and Vortex Control Notches
The NF-F12's stator guide vanes are set out in Varying Angular Distance and feature Vortex-Control Notches. Both measures help to spread the noise emission over a broader frequency spectrum and thus make the fan's sound pattern more agreeable to the human ear.
Heptaperf™ Impeller
Custom designed for the new Focused Flow™ frame and to work in tandem with the eleven stator guide vanes, the NF-F12's seven blade Heptaperf™ impeller has been carefully optimised to achieve a perfect balance between power and quietness.
Stepped Inlet Design
Noctua's Stepped Inlet Design adds turbulence to the influx in order to facilitate the transition from laminar flow to turbulent flow, which reduces tonal intake noise, improves flow attachment and increases suction capacity, especially in space restricted environments.
Inner Surface Microstructures
With the tips of the fan blades ploughing through the boundary layer created by the Inner Surface Microstructures, flow separation from the suction side of the blades is significantly suppressed, which results in reduced blade passing noise and improved airflow and pressure efficiency.
Integrated Anti-Vibration Pads
Integrated Anti-Vibration Pads made from extra-soft silicone minimise the transmission of minute vibrations while maintaining full compatibility with all standard mounting systems and fan clips used on heatsinks.
SSO2 Bearing
The NF-F12 is the first fan to feature the further optimised second generation of Noctua's renowned, time-tested SSO bearing. With SSO2, the rear magnet is placed closer to the axis to provide even better stabilisation, precision and durability.
Metal bearing shell
In order to guarantee the highest possible degree of manufacturing precision, minimum tolerance and excellent long-term stability, the NF-F12 sports a CNC milled bearing shell made entirely from brass.
Custom designed PWM IC with SCD
Supporting fully automatic PWM speed control, the NF-F12 uses Noctua's novel, custom designed NE-FD1 PWM IC that integrates Smooth Commutation Drive (SCD) technology. By providing smoother torque impulses, SCD suppresses PWM switching noises and thus makes the fan quieter at lower speeds.
Ultra-Low Power Consumption
The NF-F12 draws only 0.6W, which is more than 50% less than many fans in the same speed range. This doesn't only make it eco-friendly but also cuts down the electricity bill: Compared to a typical 2W fan, this allows you to save about half the price of the NF-F12 after 5 years of continuous use.
Low-Noise Adaptor
The NF-F12 is supplied with a Low-Noise Adaptor (L.N.A.) that reduces the maximum fan speed from 1500 to 1200rpm. The L.N.A can be used either to run the fan at a fixed speed of 1200rpm or to cap the maximum speed when using automatic PWM control.
Extensive Cabling Options
The fan's short 20cm primary cable minimises cable clutter in typical applications while the supplied 30cm extension provides extended reach when necessary. Both cables are fully sleeved and a 4-pin y-cable allows to connect a second NF-F12 fan to the same PWM fan header for automatic control.
6 years manufacturer's warranty
Noctua fans are renowned for their impeccable quality and outstanding longevity. Like all Noctua fans, the NF-F12 features an MTBF rating of more than 150.000 hours and comes with a full 6 years manufacturer's warranty.
Noctua NF-F12 PWM - case fan
Case fan
Package Content
Low-Noise Adaptor (L.N.A.), Y-Split cable, 4 screws, 4 vibration isolators
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
SSO2 bearing
Rotation Speed
300-1500 rpm
Air Flow
55 cfm
Noise Level
22.4 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
21 cm x 3.3 cm x 15 cm
314 g
6 years warranty
Case fan
Package Content
21 cm
3.3 cm
15 cm
314 g
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
SSO2 bearing
Rotation Speed
300-1500 rpm
Air Flow
55 cfm
Air Pressure
2.61 mm
Noise Level
22.4 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.05 A
Power Consumption
0.6 W
Mounting Kit
Included
MTBF
150,000 hour(s)
6 years warranty
Service & Support Details
Limited warranty - 6 years
£18.79
Save on this ideal PC Build kit!
Save £16.90
£44.14
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Best in class
Reviewed by Gareth on 27/05/2014
NF-F12's are super quiet and yet retain the static pressure of some of the more louder fans. Yes, they are a bit pricey but you get what you pay for.
I have 2 on my 240mm radiator instead of Corsair sp120's and they make a massive difference to overall acoustics. Highly recommended.
5* Great silent fan!
Reviewed by Evan Wilson on 02/09/2012
This thing is the bee's knees! It is big, quiet, and efficient! I have a single 120mm as an exhaust in my case, and it is great! The only thing I don't like is the color of it, it looks completely out of place in my case, but for the amount of time I spend looking at my case, compared to hearing my case, I have no real issue with that.
The mounting system can be a bit troublesome in tight spaces, but all in all, I would rather it doesn't rattle, than be slightly easier to install.
Will be looking to add one or two more of these in the future.
Scroll to top
