BT.com
Wishlist
Noctua NF-A14 FLX 140mm Premium Quality Fan
Noctua NF-A14 FLX 140mm Premium...
£18.38
Hurry, only 2 left in stock!
£18.38
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The NF-A14 is a premium quality quiet 140 mm fan with a square frame that complies with Noctua's AAO (Advanced Acoustic Optimization) standard. Its square shape and 140 mm mounting holes make it ideal for use on water-cooling radiators or as an upgrade for 140 mm case fans. Featuring sophisticated aerodynamic design measures such as flow acceleration channels, the NF-A14 further improves the renowned quiet cooling performance of the award-winning NF-P14. The FLX version provides 1200/1050/900 rpm speed settings via the supplied low-noise adaptors in order to provide full flexibility in fine-tuning the fan for maximum ventilation performance or near-silent operation. Its superb running smoothness, reference-class SSO2 bearing and Noctua's trusted premium quality make it an elite choice for the highest demands.
Noctua NF-A14 FLX - case fan
Case fan
Package Content
Ultra-Low-Noise Adaptor (U.L.N.A.), Low-Noise Adaptor (L.N.A.), 3-pin plug to 4-pin Molex adapter, 4 screws, 4 vibration isolators, 1 extension cable (30 cm)
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
SSO2 bearing
Rotation Speed
900/1050/1200 rpm
Air Flow
52.2-68 cfm
Noise Level
13.8 - 19.2 dBA
Power Connector
3-pin plug, 4 pin Molex connector
Rated Voltage
12 V
Advanced Acoustic Optimisation (AAO), flow acceleration channels
6 years warranty
Case fan
Package Content
Heatsink & Fan
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
SSO2 bearing
Rotation Speed
900/1050/1200 rpm
Air Flow
52.2-68 cfm
Air Pressure
0.89-1.51 mm
Noise Level
13.8 - 19.2 dBA
Power Connector
Rated Voltage
12 V
Rated Current
0.08 A
Power Consumption
0.96 W
Mounting Kit
Included
MTBF
150,000 hour(s)
6 years warranty
Service & Support Details
Limited warranty - 6 years
£18.38
Save on this ideal PC Build kit!
Save £10.36
£37.93
Scroll to top
