BT.com
Wishlist
Noctua Dual Radiator and Fan CPU Cooler Multi-Socket
Noctua Dual Radiator and Fan CPU...
£70.46
£70.46
Add to wishlist
Delivery
Standard Due date unavailable
The NH-D14 is built for ultimate quiet cooling performance. Topped off with a tube of Noctua's award-winning NT-H1 thermal compound as well as the SecuFirm2 multi-socket mounting system, the NH-D14 is an elite choice for the highest demands in premium quality quiet cooling.
Six heatpipe dual radiator design
Providing more surface area, better heat-distribution and superior airflow efficiency than conventional tower style heatsinks, the NH-D14s six heatpipe dual radiator design was developed to provide ultimate quiet cooling performance in dual fan mode.
Dual NF-P14/NF-P12 fan setup
The NH-D14 sports a premium quality dual fan setup consisting of Noctua's award-winning NF-P12 (120mm) and NF-P14 (140mm) fans, both of which feature Vortex-Control Notches, SCD technology and SSO-Bearings in order to achieve a perfect balance of performance and quietness.
Asymmetrical design for high compatibility
An asymmetrical design that gives more clearance towards the RAM slots ensures good compatibility despite of the coolers size. The NF-P12 fan can be moved upwards or left off in order to further improve compatibility.
Excellent component cooling
Hanging out at the bottom of the fin-stacks, the NF-P14 fan doesn't only contribute to the NH-D14s superb CPU cooling capabilities but also provides massive airflow over surrounding motherboard components and heatsinks, thus ensuring excellent component cooling performance.
Noctua's enthusiast grade SecuFirm2 multi-socket mounting provides broad socket compatibility (LGA1366, LGA1156, LGA775, AM2, AM2+ and AM3) and meets the highest demands in safety, contact pressure and ease-of-use.
Noctua's much-acclaimed NT-H1 is a well proven pro-grade TIM solution that provides minimum thermal resistance, excellent ease-of-use and outstanding reliability.
  • Fan Bearing SSO-Bearing
  • Fan Rotational Speed (+/- 10%) 1200 / 1300 RPM
  • Fan Rotational Speed with U.L.N.A. (+/- 10%) 900 / 900 RPM
  • Fan Airflow 64.9 / 54.3 CFM
  • Fan Airflow with U.L.N.A. 52.2 / 37.3 CFM
  • Fan Acoustical Noise 19.6 / 19.8 dB(A)
  • Fan Acoustical Noise with U.L.N.A. 13.2 / 12.6 dB(A)
  • Fan Input Power 1.2 / 1.08 W
  • Fan Voltage Range 12 V
  • Fan MTBF > 150.000 h
Noctua NH-D14 - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket
Heatsink Material
Aluminium with copper base
Fan Height
25 mm
Rotation Speed
1200-1300 rpm
Rated Voltage
12 V
Heat pipe technology
14 cm x 15.8 cm x 16 cm
1.24 kg
6 years warranty
Processor cooler
14 cm
15.8 cm
16 cm
1.24 kg
Compatible Fan Diameter
120 mm, 140 mm
Heatsink & Fan
Compatible With
Heatsink Material
Fan Height
25 mm
Rotation Speed
1200-1300 rpm
Rated Voltage
12 V
Mounting Kit
Included
MTBF
150,000 hours
6 years warranty
Service & Support Details
Limited warranty - 6 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Quiet, quick and cool and well worth the money
Reviewed by Jason on 27/10/2012
I bought one of these for my AMD 965 to run in a Fractal R3 case, to replace an aging tower cooler I was using. As I wanted my computer to be very quiet I switched the P12 and P14 fan for three, yes three P-14 fans. If you email Noctua telling them this is what you want to do, they will send you an extra set of fan holders for free! When fitted with the Ultra Silent Adapters you can only just hear the fans 1 meter away from the case. Not only are they quiet, but I also managed to overclock my 965 from 3.4GHz to 3.9GHz by simply upping the multiplier. With 100% load for an hour, none of the processor cores go above 45 degrees. This cooler might look expensive, but its very well made and is very efficient.
5* Notua DH14
Reviewed by Samuel A.B on 30/12/2011
CPU Cooler is a beast a massive dual fan cooler.
Ease of use was rather tricky to fit especially when installing into the case once its fitted with its backplate. Quite heavy as well might need a helping hand when fitting the backplate.
Not for the faint hearted as this is a enthusiasts cooler, the cooler can only fit low profile memory sticks like Kingston Hyper X sticks. So be warned but there be saving grace as there's two orientations to place the cooler over the mobo heat sinks or place it over the memory slots.
But after installation it works like a dream, it cools my i5 2500k stock @ speed 3.3ghz at 20c. It can tend to get a bit louder when the cpu gets stressed. But luckily you can tweak the fan when the full 1200RPM kicks in when it gets a bit too much though in the bios changing the fan speed to lower RPM.
5* Makes overclocking so easy!!!
Reviewed by Bobby on 02/03/2012
A+ product, overclocked my i7 2700K to 4.8Ghz and temps were 25c IDLE and full load 50c!
Scroll to top
