Click to visit BT.com
BT.com
Wishlist
Nikon D5200 - DSLR - 18-55mm VR Lens - 24.1 Mpix - red
Quicklinx: 8J8NWS00
Mfr#: VBA351K001
Essential accessories
Discover new perspectives with the inspirational D5200.
From breathtaking photos to smooth Full HD movies, this D-SLR can't wait to bring out your creative side.
The flexible vari-angle monitor empowers your vision with unique views. The 24.1-megapixel DX-format CMOS sensor captures finely detailed images, and the advanced 39-point autofocus system is always on target. Nikon's amazingly accurate 2,016-pixel light metering sensor ensures exact exposures in even difficult lighting conditions.
You can render special effects for movies or stills in real time, and Nikon's wireless mobile adapter lets you send your creations straight to a compatible smart device for instant sharing.
24.1-MP DX-format CMOS sensor
Capture beautifully detailed photos and movies. You can crop images without losing any detail, and big prints of your photographs look superb.
Vari-angle monitor
Flip it, tilt it, turn it--explore your creativity with this versatile swivel monitor. Capture unique shots, including great self-portraits, from any angle.
Inspire yourself with D-Movie
Record finely detailed Full HD video clips you'll want to share. Take advantage of smooth recording (up to 60i/50i) and a built-in stereo microphone.
Wireless Mobile Adapter WU-1a
Share images directly from the D5200 to a smartphone or tablet that runs on Android™ or iOS™, or control the camera remotely via your device.
EXPEED 3
Nikon's fast and powerful image processing engine provides high-speed operation, remarkably clear images with excellent color reproduction, and enhanced movie recording.
High ISO (100-6400, extendable to 25600 equivalent)
Enjoy the freedom that great low-light performance brings. Capture detailed images in dark situations and clear shots of fast-moving subjects.
39-point AF system
With 39 focus points (from which 9 are cross-type) for superior accuracy. Advanced 3D subject tracking maintains focus on even the smallest subjects, however unpredictable their movements may be.
2,016-pixel RGB metering sensor
Delivers precise metering for exact exposures and sends data to the Scene Recognition System, which optimizes auto exposure, autofocus, and auto white balance.
Effects mode
Create distinctive photos and movies using a range of special effects, including Selective Color and Miniature. You can view your chosen effect in real time as you shoot.
5 fps continuous shooting
Shoot action at a swift five frames-per-second and capture fleeting movements or expressions at exactly the right moment.
D-Movie AF modes
Live view autofocus works as you shoot movie clips. Keep subjects in sharp focus with full-time servo AF (AF-F). Relax and let the camera keep track of your subject with subject-tracking AF or face-priority AF.
HDR (High Dynamic Range)
Capture more detail when you shoot in high-contrast lighting conditions. Ideal for stationary subjects, the camera takes two shots at different exposures during a single shutter release, and then combines them into one stunning image with natural contrast.
Active D-Lighting
Retain the details in both dark and bright areas when you shoot images in strong light, or in backlit situations. Ideal for photos of moving subjects.
16 scene modes
Capture great shots just by selecting the mode that matches the subject or situation you're shooting. Scene modes optimize settings like shutter speed, ISO, and aperture, which is ideal if you want to quickly capture perfect shots or are new to D-SLR photography.
High-resolution LCD
See every detail of your photos and movies thanks to the high-resolution 7.5 cm (3.0-in.), 921k-dot vari-angle LCD monitor with wide-viewing angle and high contrast ratio. Compose shots or apply special effects with clarity whether you're shooting indoors or out.
Intelligent design
The small, lightweight body and superior ergonomics make this camera a pleasure to shoot with. A secure grip ensures a comfortable hold. Clear menus and one-touch buttons for frequently used functions like D-Movie and Live View make operation quick and intuitive.
Wireless remote control
Nikon's WR-R10 and WR-T10 wireless remote control devices are optional accessories that let you control key camera functions from a distance, even if there are obstacles between yourself and the camera. Ideal for shooting self-portraits, these devices can help prevent camera shake during shutter release.
NIKKOR lenses
Take advantage of Nikon's legendary NIKKOR lenses and make the most of the camera's 24-megapixel resolution. Capture photos with vivid color and striking contrast. Shoot movies with crisp detail or experiment with cinematic effects
Nikon D5200 - digital camera AF-S VR DX 18-55mm lens
Digital camera - SLR with Live View mode, movie recording
Lens Included
Memory Card Slot
SD card
Image Processor
EXPEED 3
Sensor Resolution
24.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
3 x zoom lens - 18 - 55 mm - f/3.5-5.6 G ED II Nikon AF-S DX
Focus Adjustment
Automatic, manual
Min Focus Distance
28 cm
Image Stabiliser
Optical
Camera Flash
Pop-up flash
Viewfinder
Optical - eye-level pentamirror
Display
LCD display - 3"
Supported Battery
1 x Nikon EN-EL14 Li-ion rechargeable battery ( included )
AV Interfaces
Composite video/audio, HDMI
Microsoft Certification
Compatible with Windows 7
Red
12.9 cm x 9.8 cm x 7.8 cm
505 g
Lens Included
Enclosure Colour
Red
Sensor Resolution
24.1 Megapixel
Optical Sensor Type
CMOS
Total Pixels
24,710,000 pixels
Effective Sensor Resolution
24,100,000 pixels
Optical Sensor Size
15.6 x 23.6mm
Field of View Crop Factor
1.5
Sensor Dust Reduction
Sensor Features
Air flow control system, Self Cleaning Sensor Unit
Optical Zoom
3 x
Image Processor
EXPEED 3
Image Stabiliser
Optical
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
39
AE/AF Control
3D-tracking AF, Auto-area AF, Face-priority AF, Subject-tracking AF
Digital Video Format
H.264, MOV
Image Recording Format
JPEG, RAW + JPEG, NEF (RAW)
1920 x 1080
AV Interfaces
Exposure & White Balance
Light Sensitivity
ISO auto, ISO 12800, ISO 25600, ISO 100-6400
Exposure Metering
Centre-weighted, 3D colour matrix II, colour matrix II, spot (2.5%)
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority, i-TTL program flash
Shooting Programs
Autumn colour, landscape, portrait mode, close-up, party/indoor, beach/snow, night portrait, Children, food, night landscape, dawn/dusk, sports mode, sunset, candle, blossom, pet portrait
Special Effects
Neutral, Vivid, monochrome, landscape, portrait, miniature, Silhouette, Colour sketch, Selective Colour, High Key, Night Vision, Low Key
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, sunlight, Flash, shade
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/2 or 1/3 EV steps
White Balance Bracketing
X-sync Speed
1/200sec
Exposure Range
EV 0-20 ( ISO 100 )
Lens System
Focal Length Equivalent to 35mm Camera
27 - 82.5mm
Focus Adjustment
Automatic, manual
Min Focus Distance
28 cm
Max View Angle
76 degree(s)
Zoom Adjustment
Manual
Lens Construction
5 groups / 7 elements
Filter Size
52 mm
Lens System Mounting
Nikon F
Full-time manual focusing, ED glass, Silent Wave Motor (SWM), aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
13
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation, wireless off-camera control
Additional Features
Continuous Shooting Speed
3 frames per second, 5 frames per second
Self Timer Delay
10 sec, 2sec, 5 sec, 20sec
Flash Terminal
Hot shoe
Additional Features
Audio recording, direct print, USB 2.0 compatibility, date/time stamp, DPOF support, display brightness control, digital image rotation, camera orientation detection, PictBridge support, histogram display, AE lock, AF lock, GPS ready, LCD live view mode, highlight point display, Active D-Lighting technology, 1080p Full HD movie recording, Dust Delete Data system, face detection, Scene Recognition System (SRS), Exif Print support, in-camera RAW processing, HDR image enhancement technology, distortion control, perspective control, long exposure noise reduction
Viewfinder
Viewfinder Type
Field Coverage
95%
Magnification
0.78x
Dioptric Correction Range
-1 to +0.7
Display
3" LCD display
Resolution
921,000 pixels
Display Features
Rotating
Microphone
Microphone Operation Mode
Stereo
Connector Type
1 x Hi-Speed USB , 1 x HDMI output , 1 x composite video/audio output , 1 x microphone
Memory Card Slot
SD card
Software
Software
Nikon ViewNX 2
System Requirements for PC Connection
Peripheral Devices
USB port, CD-ROM Drive
Eyepiece cover, battery charger, body cap, neck strap, USB cable, eyecup, shoe cap, audio / video cable
Battery Type
Nikon EN-EL14
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
6000 x 4000 , 4496 x 3000 , 1992 x 2000
Video Capture
H.264 - 1920 x 1080 - 60 fps , H.264 - 1920 x 1080 - 50 fps , H.264 - 1920 x 1080 - 30 fps , H.264 - 1920 x 1080 - 25 fps , H.264 - 1920 x 1080 - 24 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 1280 x 720 - 50 fps , H.264 - 640 x 424 - 30 fps , H.264 - 640 x 424 - 25 fps
12.9 cm
9.8 cm
7.8 cm
505 g
