BT.com
Wishlist
Nikon D5100 Digital SLR Camera - Body Only
Free delivery
Delivery
Standard Due date unavailable
The D5100 is a high-performance D-SLR designed to stimulate your creative side and help you create still images and movies like no other.
The swing-out vari-angle monitor combines with the camera's D-movie function to enable unique shots from any angle. Still images or movies can be shot using a special effect to add a sense of magic.
High Dynamic Range imaging lets you capture exquisitely detailed stills of high-contrast scenes. The perfect way to capture your view of the world, this camera was made with freedom of expression in mind.
16.2 megapixel DX-format CMOS image sensor: delivers lifelike images with vivid colors, reduced noise and smooth tonal gradations.
High ISO (100-6400) light sensitivity - manually extendable up to 25600 using the Hi2 setting. Enables faster shutter speeds for finely detailed images with minimal noise when you shoot fast-moving subjects or take pictures in low light. Features an Auto ISO setting.
EXPEED 2 image processing engine: optimizes the camera's technologies for superior performance and maximum image quality.
7.5 cm (3-in.), 921k-dot vari-angle LCD monitor with wide viewing angle: lets you capture unique shots from any angle. Boasts a side opening mechanism that makes it easy to shoot self-portraits or use a tripod.
D-Movie - full HD (1080p) movie clips: a dedicated movie-record button right next to the shutter-release makes it easy to keep the camera steady when you switch between recording stills and movies. AF-F mode keeps everything in focus, and the camera's vari-angle monitor and Special Effects mode enable unique shots. The camera supports use of an external microphone and offers 30p, 25p and 24p frame rates.
Live View with Scene Auto Selector: makes it easy to compose images using the vari-angle LCD monitor. Scene Auto Selector will select the best mode for the scene and subject you want to capture. Boasts easily selectable AF modes, including Face Priority AF that detects and tracks faces within the frame.
Razor-sharp 11-point AutoFocus system: offers fast and precise autofocus coverage across the frame. Four AF-area modes, including 3D-tracking AF, deliver sharp results, whether your subject is off-center, moving fast or completely unpredictable.
4 fps continuous shooting: enables you to capture fast-moving action at four frames per second.
Special Effects mode: lets you shoot distinctive still images and movies using a special effect. Offers a range of effects, including Color Sketch, Miniature effect, Night Vision and Selective Color that lets you emphasize up to three colors of your choice and turns the rest of the image to monochrome.
Scene Modes automatically adjust camera settings, including Picture Controls and active D-Lighting, to take the guesswork out of tricky photo situations and deliver optimal results. Simply turn the mode dial to SCENE to access the most commonly used modes. Sample photos appear on the display to help you select the right mode.
HDR (High Dynamic Range) imaging: delivers exquisitely detailed shots of high-contrast scenes. Takes two shots within a single shutter release to create an image with an extremely wide dynamic range, low noise and rich color gradation.
Extensive in-camera Retouch Menu: lets you edit and enhance photos and movies in the camera. Offers a range of effects and filters including Perspective Control, Soft Focus and Color Outline, which transforms your photo into a line drawing.
Dual Integrated dust reduction system: Image Sensor Cleaning and Airflow Control systems keep dust away from the camera's image sensor for clear, spot-free images.
HDTV compatibility: camera features a built-in HDMI connector with HDMI-CEC support so you can view your photos and movies on any HDTV and control playback features using your TV's remote control.
Infrared front and back receiver: helps prevent image blur when shooting close-ups and self-portraits.
Stereo sound: designed specifically for D-SLRs, Nikon's optional Stereo Microphone ME-1 lets you record movie clips in high-quality stereo sound, with no AF noise. Comes with windscreen and soft case accessories.
Nikon D5100 - digital camera - body only
Digital camera - SLR with Live View mode, movie recording
Lens Included
Body only
Memory Card Slot
SD card
Image Processor
EXPEED 2
Sensor Resolution
16.2 Megapixel
Max Video Resolution
1920 x 1080
Camera Flash
Pop-up flash
Viewfinder
Optical - eye-level pentamirror
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery ( included )
AV Interfaces
Composite video/audio, HDMI
Microsoft Certification
Compatible with Windows 7
12.7 cm x 7.9 cm x 9.7 cm
560 g
Lens Included
Body only
Sensor Resolution
16.2 Megapixel
Optical Sensor Type
CMOS
Total Pixels
16,900,000 pixels
Effective Sensor Resolution
16,200,000 pixels
Optical Sensor Size
15.6 x 23.6mm
Field of View Crop Factor
1.5
Sensor Dust Reduction
Sensor Features
Air flow control system, Self Cleaning Sensor Unit
Image Processor
EXPEED 2
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
11
AE/AF Control
3D-tracking AF, Face-priority AF, Subject-tracking AF
Digital Video Format
H.264, MOV
Image Recording Format
JPEG, RAW + JPEG, NEF (RAW)
1920 x 1080
AV Interfaces
Exposure & White Balance
Light Sensitivity
ISO auto, ISO 12800, ISO 25600, ISO 100-6400
Exposure Metering
Centre-weighted, 3D colour matrix II, colour matrix II, spot (2.5%)
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority, i-TTL program flash
Shooting Programs
Autumn colour, landscape, portrait mode, close-up, party/indoor, beach/snow, night portrait, Children, food, night landscape, dawn/dusk, sports mode, sunset, candle, blossom, pet portrait
Special Effects
Neutral, Vivid, monochrome, landscape, portrait, miniature, Silhouette, Colour sketch, Selective Colour, High Key, Night Vision, Low Key
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, sunlight, Flash, shade
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/2 or 1/3 EV steps
White Balance Bracketing
X-sync Speed
1/200sec
Exposure Range
EV 0-20 ( ISO 100 )
Lens System
Lens System Mounting
Nikon F
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
12
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation, wireless off-camera control
Additional Features
Continuous Shooting Speed
4 frames per second
Self Timer Delay
10 sec, 2sec, 5 sec, 20sec
Flash Terminal
Hot shoe
Additional Features
Audio recording, direct print, USB 2.0 compatibility, date/time stamp, DPOF support, display brightness control, digital image rotation, camera orientation detection, PictBridge support, histogram display, AE lock, AF lock, in-camera red-eye removal, cropping an image, resizing an image, GPS ready, LCD live view mode, face-priority AF function, highlight point display, Active D-Lighting technology, 1080p Full HD movie recording, Dust Delete Data system, face detection, built-in help guide, Scene Recognition System (SRS), Exif Print support, in-camera RAW processing, Eye-Fi Card Ready, Live View Scene Auto Selector, distortion control, perspective control
Viewfinder
Viewfinder Type
Field Coverage
95%
Magnification
0.78x
Dioptric Correction Range
-1 to +0.7
Display
3" LCD display
Resolution
921,000 pixels
Display Features
Rotating
Microphone
Microphone Operation Mode
Mono
Connector Type
1 x Hi-Speed USB , 1 x HDMI output , 1 x composite video/audio output , 1 x microphone
Memory Card Slot
SD card
Software
Software
Nikon ViewNX 2
System Requirements for PC Connection
Peripheral Devices
USB port, CD-ROM Drive
Battery charger, body cap, neck strap, USB cable, eyecup, shoe cap, audio / video cable
Battery Type
Nikon EN-EL14
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
4928 x 3264 , 3696 x 2448 , 2464 x 1632
Video Capture
MOV - 1920 x 1080 - 30 fps , MOV - 1920 x 1080 - 25 fps , MOV - 1920 x 1080 - 24 fps , MOV - 1280 x 720 - 30 fps , MOV - 1280 x 720 - 25 fps , MOV - 1280 x 720 - 24 fps , MOV - 640 x 424 - 30 fps , MOV - 640 x 424 - 25 fps
12.7 cm
7.9 cm
9.7 cm
560 g
Scroll to top
