Click to visit BT.com
BT.com
Wishlist
Nikon D3200 Digital SLR Camera - Black - 18-55mm VR Lens Kit
Quicklinx: 823QWS00
Mfr#: VBA330K001
Essential accessories
Don't let the D3200's compact size and price fool you -- packed inside this easy to use HD-SLR is serious Nikon power: a 24.2 MP DX-format CMOS sensor that excels in any light, EXPEED 3 image-processing for fast operation and creative in-camera effects, Full HD (1080p) movie recording, in-camera tutorials and much more. What does this mean for you? Simply stunning photos and videos in any setting. And now, with Nikon's optional Wireless Mobile Adapter, you can share those masterpieces instantly with your Smartphone or tablet!
Featuring 24.2 effective megapixels, the D3200 employs a Nikon-developed DX-format CMOS image sensor. It achieves high-resolution rendering and rich tonal gradation that smoothly reproduces human skin texture and gradation of sky. Also, utilizing the large sensor of a D-SLR, high-quality still images and movies can be taken with beautiful background blur. The high pixel count of the D3200 is also effective when images are printed. Even when taken still images are trimmed and enlarged, high-resolution image quality is realized with the least degradation.
To process 24.2-megapixel data at high speed, an image-processing engine EXPEED 3, the same as that used by the Nikon D4, that is optimized for D-SLRs is incorporated. EXPEED 3 realizes faithful reproduction of human skin, expanded dynamic range and improved color rendering in Active D-Lighting. With its high-performance noise-reduction function, rich gradation with less noise is achieved even at a high sensitivity range, for both still images and movies.
The D3200 analyzes color and brightness information of the scene utilizing the light source identification function of Scene Recognition System and detects the light source precisely by referencing the in-camera database for auto white balance. In this way, it can determine the ideal white balance even with difficult light sources.
It is difficult to reproduce the brightness of subjects as it appears in such scenes as a dark room including outside scenery seen through a window, high-contrast scenes such as at the seaside under strong sunlight, and backlit situations. The D3200 employs active D-lighting that preserves details in both highlights and shadowy areas in such situations, maintaining moderate contrast. You can reproduce brightness as you see it in both bright and dark situations.
With D-SLRs, it sometimes occurs that dust becomes attached to the OLPF (optical low-pass filter) located in front of the image sensor when exchanging lenses, and is photographed in taken images. To prevent dust from degrading images, the D3200 employs the Image Sensor Cleaning function and Airflow Control System. These double measures effectively reduce the possibility of dust being photographed in the frame, ensuring beautiful images.
The D3200 employs guide mode that enables you to take pictures and movies the way you want, even if you are a first-time user of a D-SLR. By just following the guides displayed in the monitor, a variety of image expression is realized easily, such as "soften background" to emphasize the subject, "capture reds in sunsets", or "take bright/dark photos".
Features Explained
Image Quality:
Nikon DX-format CMOS sensor realizes beautiful reproduction of human skin, gradation of sky and background blur
Image-processing engine EXPEED 3 - the same as that used by the Nikon D4 FX-format flagship camera - is employed
Also, with high-speed readout from the image sensor integrated with superior image-processing capability, Full HD D-Movie at 1,920 x 1,080/30p is supported.
Wide sensitivity range up to ISO 6400 - effective for shooting in dark situations and for moving subjects
Wide sensitivity range from ISO 100 to 6400 is provided. Superior high-sensitivity performance is offered even with high pixel count. The range can be increased up to Hi 1 (ISO 12800 equivalent). Even at high ISO setting, sharp images are delivered with minimized noise while maintaining resolution. Setting high ISO sensitivity enables you to shoot at faster shutter speeds and capture pictures without worrying about image degradation caused by camera shake even when shooting at night or in dark interiors, or when shooting a moving subject such as children or pets. Furthermore, this superior high-sensitivity performance is effective for D-Movie and you can shoot beautiful movies without large-scale lighting equipment even in low-light conditions.
Identifies the situation of the subject precisely for reliable auto control - Scene Recognition System
Utilizing a 420-pixel RGB sensor, the camera detects brightness and colors finely, and identifies the situation of the subject accurately before shooting. The results are reflected in autofocus, auto exposure, i-TTL flash control and auto white balance for accurate auto control. Moreover, the D3200 detects human faces utilizing the Face Detection System, and applies the information to autofocus, auto exposure, auto white balance and playback zoom of face.
Identifies the light source precisely - auto white balance
Reproduces brightness as you see it - Active D-Lighting
It is difficult to reproduce the brightness of subjects as it appears in such scenes as a dark room including outside scenery seen through a window, high-contrast scenes such as at the seaside under strong sunlight, and backlit situations. The D3200 employs Active D-Lighting that preserves details in both highlights and shadowy areas in such situations, maintaining moderate contrast. You can reproduce brightness as you see it in both bright and dark situations.
Double countermeasures to reduce image-degrading dust - Image Sensor Cleaning function and Airflow Control System
Vibrations at multiple different resonant frequencies are used to reduce dust on the low-pass filter. This function is automatically activated each time the camera is turned on and off. It can also be activated from the menu.
This controls the flow of air using small ducts near the lens mount, preventing internal dust from sticking to the low-pass filter in front of the image sensor.
NIKKOR
NIKKOR is Nikon's lens brand that is highly praised by countless photo enthusiasts and professionals. NIKKOR has always led the way by incorporating Nikon's original technologies. With its superior optical quality and an extensive lineup, NIKKOR maximizes the high image quality of the D3200's 24.2 effective megapixels, thus delivering excellent imaging performance for both stills and movies.
Technologies that only Nikon can offer
-Nikon's original Vibration Reduction (VR) even compensates blur in the viewfinder image for comfortable handheld shooting
When shooting in dark locations, it is necessary for the camera to open the shutter for an extended period of time to receive sufficient light. This may result in a blurred image caused by camera shake. Nikon built the VR function into the lens to reduce the effects of camera shake. Different from a blur-reduction function built into the camera body, this ensures a stable viewfinder image during shooting for comfortable shooting. The VR function is effective for sports and dusk or night scenes where image blur may be caused with handheld shooting.
-AF-S lenses with built-in SWM (Silent Wave Motor) ensure quiet autofocus operation
Nikon's original SWM (Silent Wave Motor) for AF drive is an autofocus motor that converts "traveling waves" into rotational energy to drive optics for autofocus. AF-S lenses that incorporate the SWM achieve quiet AF operation.
-Nano Crystal Coat provides clear images with minimal ghost or flare
This is an antireflective coating that originated from Nikon's work in semiconductor manufacturing technology. Ghost effects caused by red light, which were incredibly difficult to prevent with previous systems, and ghost and flare effects caused by light entering the lens diagonally are effectively reduced.
-ED glass effectively minimizes chromatic aberration at high magnification
Nikon-developed ED (Extra-low Dispersion) glass minimizes prism-caused color dispersion. For lenses using normal optical glass, the longer the focal length, the more difficult it is to correct the chromatic aberration that causes color fringing. Nikon's ED glass effectively compensates for this kind of chromatic aberration.
-Aspherical lens for effective distortion correction
This type of lens utilizes non-spherical surfaces to correct certain types of lens aberration. These elements are particularly useful for correcting the distortion in wide-angle lenses.
Easy operation:
Easier-to-use Guide Mode that shows you exactly how to take great pictures
The D3200 employs Guide Mode that enables you to take pictures and movies the way you want, even if you are a first-time user of a D-SLR. By just following the guides displayed in the monitor, a variety of image expression is realized easily, such as "Soften background" to emphasize the subject, "Capture reds in sunsets", or "Take bright/dark photos".
Shooting using viewfinder
Easy-to-see viewfinder Optical viewfinder shooting is convenient in high-speed continuous shooting or when tracking a moving subject. The D3200 features approx. 95% frame coverage and approx. 0.8x magnification. The clear and easy-to-see viewfinder supports comfortable shooting with minimal time lag.
11-point AF system
11-point AF system for reliable subject acquisition The D3200 incorporates a high-speed and highly accurate 11-point AF system. A cross-type sensor covers the most frequently used center area to deliver superior subject-acquisition and focusing performance. With Scene Recognition System, the D3200 shows enhanced subject identification and composition change detection. In Auto-area AF mode, the D3200 achieves focus at the appropriate focus point by detecting background, foreground and subject. In 3D-tracking (11 points) mode, the focus point automatically changes to track the subject even if it moves or composition is changed while the shutter-release button is pressed halfway. Also, the camera employs superimposed indicators for bright and easy-to-see viewfinder information. Focus points are displayed clearly.
Superior durability, accuracy and operability - highly reliable shutter
The D3200's shutter unit is tested for 100,000 cycles with the shutter actually loaded to prove its high durability. The release mode button/Self-timer button/Remote control button on the camera back enables selection of release modes from Single frame, Continuous, Self-timer, Delayed Remote (2 s), Quick-response remote and Quiet shutter release. The Quiet shutter release mode is convenient when you want to shoot with reduced shutter-release sound for occasions such as a school play or when taking pictures of wildlife, insects, or a sleeping child. It also contributes to high-speed continuous shooting at approx. 4 fps
Comfortable live view shooting using a large LCD monitor
Live view shooting using an LCD monitor feels more like shooting with a compact digital camera. This is convenient when it is difficult to use the viewfinder to take high-angle or low-angle shots, or when you want to determine composition using approx. 100% frame coverage in landscape or portrait photography. You can shoot while confirming your subject with the large, easy-to-view, 7.5-cm (3-in.) VGA (approx. 921k-dot), LCD monitor. The desired AF area can be selected by moving a focus point with the multi selector. For close-up shooting of flowers and other small subjects using a tripod, you can magnify images up to approx. 9.4 times to check the exact focus.
Three focus modes - selectable according to your subject
-Single-servo AF (AF-S)
Suitable for a stationary subject such as landscapes, architecture or flowers.
-Full-time-servo AF (AF-F)
Convenient for shooting a moving subject which is usually difficult to focus on, such as a child or pet. Available in both live view mode and movie recording. Camera focuses continuously as the subject moves.
-Manual focus (MF)
Manual focusing. Suitable for a subject for which autofocus is difficult, such as an animal in a cage or a person in the shade with the sun in the background.
Four AF-area modes - automatically focus on someone's face or a moving subject
-Face-priority AF -Face-priority AF
Ideal for focusing on someone's face such as for a commemorative photo.
-Wide-area AF
Suitable for handheld shooting such as for a landscape. AF area can be moved to a desired point within the frame.
-Normal-area AF
Convenient for shooting with pin-point focus for a designated position such as for a close-up of a flower. Using a tripod is recommended for more precise focusing.
-Subject-tracking AF
After focusing is activated, AF area tracks the subject. Ideal for capturing a moving subject such as a child or pet.
Images taken with the D3200 can easily be transmitted to smart devices wirelessly [NEW]
When the optional WU-1a Wireless Mobile Adapter is connected to the D3200, it is possible to transmit images to a smart device such as a smartphone or tablet PC wirelessly. Beautiful images that only D-SLRs can capture are now available for SNS or email. Moreover, a remote shooting function that enables shutter release from a distant place is employed. You can take shots from a wide shooting angle, while confirming an image to be taken, with a smart device as a live view display. Android OS smart devices are supported.
Long-life battery due to energy-saving design - EN-EL14 Rechargeable Li-ion Battery
EN-EL14 Rechargeable Li-ion Battery (supplied) The D3200's efficient energy-saving design allows you to shoot approx. 540 shots per charge with the EN-EL14 Rechargeable Li-ion Battery
D-Movie
Records movies more beautifully and easily with a D-SLR - Full HD D-Movie
The D3200 offers Full HD movie recording at 1,920 x 1,080/30p. You can shoot beautiful movies utilizing 24.2 effective megapixels. It is possible to record movies with expanded image expression utilizing beautiful blur that only D-SLRs can offer, a variety of perspectives with a wide interchangeable lens lineup, and superior high-sensitivity performance. When subject-tracking AF is used, even a moving subject is kept focused. The movie-record button is located next to the shutter-release button to enable instant movie recording start. You can record movies as if using a video camcorder. With the D3200, manual setting for movie recording is possible (only when exposure mode is set to M). You can set shutter speed and ISO sensitivity before starting recording*. Furthermore, a flicker reduction function is employed to enable you to select flicker frequency (50Hz/60Hz) or choose automatic.
How to improve your D-Movie expression
-Use a tripod in movie recording
In movie shooting, panning (tracking a subject's movement horizontally) and tilting (tracking vertically) will result in beautiful images. For smooth panning and tilting, use of a tripod is recommended because image blur caused by camera shake is likely to occur in handheld shooting.
-Controlling the background blur
Recent D-SLR cameras enable movie recording that emphasizes the background blur effect. With the D3200, you can control the degree of blur by changing the aperture (f-number) before recording.
-Wide NIKKOR lens lineup
One of the great advantages of D-SLRs is that you can enjoy diversified movie expression by changing lenses. Use a telephoto zoom lens to capture distant children at an athletic meeting, trains or airplanes, a wide-angle zoom lens for shooting landscapes, a standard zoom lens or micro lens for a baby or pets, or a fisheye lens when you want to creatively deform architecture. Using a variety of interchangeable NIKKOR lenses will make your movie recording much more enjoyable.
-Utilize Picture Control
With six types of Picture Control incorporated in the D3200, you can freely manage the colors and mood of your images by choosing an option of monochrome, vivid, etc. as you do for still images.
In-camera movie editing functions
You can edit your movie easily without a PC. It is possible to delete unwanted parts by choosing the start or end point in single frame units, and save a selected frame as a JPEG image with the same image size as that of the selected movie frame.
  • 24.2 MP DX-format CMOS sensor and EXPEED 3
    Why do photos and videos shot with a Nikon HD-SLR look so good? It all starts with Nikon’s exclusive image sensors, and the D3200 has the most powerful CMOS sensor we’ve ever put in a HD-SLR at this level. Boasting an astounding 24.2 effective megapixels, it captures sharper, richer images—even in low light. Combine that with EXPEED 3 image processing, the processing power behind the acclaimed Nikon D4, for super-fast operation, exceptional image capture, in-camera filter effects and more. Your photos and videos will amaze even you.
  • Guide Mode ensures success
    It’s never been easier to create HD-SLR quality photos, thanks to the D3200’s Guide Mode. Learn the camera's key features and controls while you shoot, and even get advice and sample images to succeed in difficult shooting situations. Guide Mode is easy to access and easy to understand. You’re never shooting alone with the D3200.
  • Six Scene Modes and Scene Auto Selector
    Experienced photographers optimize their camera settings for the scene they’re shooting. With the D3200, optimizing your camera settings is as easy as turning a dial. Choose from six common Scene Modes like Portrait, Night Portrait, Landscape, Close up and more, for flawless results even in demanding circumstances. When using Live View, Scene Auto Selector automatically sets the D3200 for the most suitable Scene Mode for the situation. A highly accurate 420-pixel RGB sensor powers Nikon's Scene Recognition System, which compares scene data against an extensive database to optimize the shot accordingly.
  • One-touch Full HD 1080p movie recording with stereo sound
    Nikon is committed to developing HD-SLRs that are not just superlative still image cameras, but superlative video cameras, as well. With a touch of a button, the D3200 starts recording Full HD 1080p video with full-time autofocus, manual exposure control and stereo sound. Its breathtaking 921,000-dot, ultra-high-resolution display makes it easy to frame, monitor and review your footage. Even record in super-smooth slow motion up to 60 fps! Unleash your inner cinematographer
  • Versatile AF-S Zoom-NIKKOR 18-55mm
    Nikon’s renowned NIKKOR lenses have long been the choice of pros and serious photographers. Marvels of clarity, consistency, precision and reliability, they draw peak performance from Nikon HD-SLRs. The D3200 comes equipped with the AF-S DX Zoom-NIKKOR 18-55mm, a versatile, high performance VR image stabilized lens. And when you’re ready to expand your system and extend your creativity, you'll have your choice of over 70 legendary NIKKOR lenses.
  • Fast and accurate shooting
    The D3200's 11-point Autofocusing System is as fast as it is precise. Check your focus points, track your subject or shoot carefree right from the viewfinder. And when the action speeds up, simply aim, hold down the shutter and fire off approx. 4 fps at 24.2 MP resolution
  • Wi-Fi Connectivity—Now you can easily get GREAT pictures on your smartphone
    Using the WU-1a optional wireless mobile adapter you can now automatically send great images to your smartphone and even use your smartphone to remotely capture images from your D3200. With an easy to use app, now, when you can't wait to share that great shot, you don't have to. Share it to your smartphone in an instant.
  • Compact, lightweight and durable
    Your D3200 is designed for comfort, intuitive use and durability. Its compact, lightweight and rugged body puts key controls at your fingertips. You'll never hesitate to bring along your D3200
  • Dramatic low-light photos
    The D3200’s wide ISO range of 100 to 6400 allows for shooting in very low light without a flash or in very bright light with zoom, macro, fixed focal length or wide aperture lenses. For extreme low-light situations, set the ISO to Hi 1 and achieve ISO 12800 equivalent sensitivity
Nikon D3200 - digital camera AF-S VR DX 18-55mm lens
Digital camera - SLR with Live View mode, movie recording
Lens Included
Memory Card Slot
SD card
Image Processor
EXPEED 3
Sensor Resolution
24.2 Megapixel
Max Video Resolution
1920 x 1080
Lens System
3 x zoom lens - 18 - 55 mm - f/3.5-5.6 G Nikon AF-S DX VR
Focus Adjustment
Automatic, manual
Min Focus Distance
28 cm
Image Stabiliser
Optical
Camera Flash
Pop-up flash
Viewfinder
Optical - eye-level penta-dach mirror
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery ( included )
AV Interfaces
Composite video/audio, HDMI
Microsoft Certification
Compatible with Windows 7
12.5 cm x 7.7 cm x 9.6 cm
455 g
Lens Included
Enclosure Colour
Sensor Resolution
24.2 Megapixel
Optical Sensor Type
CMOS
Total Pixels
24,700,000 pixels
Effective Sensor Resolution
24,200,000 pixels
Optical Sensor Size
15.4 x 23.2mm
Field of View Crop Factor
1.5
Sensor Dust Reduction
Sensor Features
Air flow control system, Self Cleaning Sensor Unit
Optical Zoom
3 x
Image Processor
EXPEED 3
Image Stabiliser
Optical
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
11
AE/AF Control
3D-tracking AF, Face-priority AF, Subject-tracking AF
Face Detection
Face Detection AF/AE/FE/WB, face zoom, face-priority AF function
Digital Video Format
H.264, MOV
Image Recording Format
JPEG, RAW + JPEG, NEF (RAW)
1920 x 1080
AV Interfaces
Exposure & White Balance
Light Sensitivity
ISO auto, ISO 12800, ISO 100-6400
Exposure Metering
Centre-weighted, spot, 3D colour matrix II
Exposure Metering Zones
420
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, close-up, night portrait, Children, sports mode
Special Effects
Neutral, Vivid, monochrome, landscape, portrait
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, sunlight, Flash, shade
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/3 EV steps
X-sync Speed
1/200sec
Exposure Range
EV 0-20 ( ISO 100 )
Lens System
Focal Length Equivalent to 35mm Camera
27 - 82.5mm
Focus Adjustment
Automatic, manual
Min Focus Distance
28 cm
Max View Angle
76 degree(s)
Zoom Adjustment
Manual
Lens Construction
8 groups / 11 elements
Filter Size
52 mm
Lens System Mounting
Nikon F
Silent Wave Motor (SWM), aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
12
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation, wireless off-camera control
Additional Features
Continuous Shooting Speed
4 frames per second
Self Timer Delay
10 sec, 2sec, 5 sec, 20sec
Flash Terminal
Hot shoe
Additional Features
Direct print, USB 2.0 compatibility, date/time stamp, DPOF support, display brightness control, digital image rotation, camera orientation detection, PictBridge support, histogram display, AE lock, AF lock, in-camera red-eye removal, cropping an image, GPS ready, Wi-Fi ready, LCD live view mode, highlight point display, Active D-Lighting technology, 1080p Full HD movie recording, face detection, built-in help guide, Scene Recognition System (SRS), Exif Print support, in-camera RAW processing, Eye-Fi Card Ready
Viewfinder
Viewfinder Type
Field Coverage
95%
Magnification
0.8x
Dioptric Correction Range
-1.7 to +0.5
Display
3" LCD display
Resolution
921,000 pixels
Display Features
Built-in
Microphone
Microphone Operation Mode
Mono
Microphone Features
Sensitivity control
Connector Type
1 x Hi-Speed USB , 1 x HDMI output , 1 x composite video/audio output , 1 x microphone ( mini-phone stereo 3.5 mm ) , 1 x remote control
Memory Card Slot
SD card
Software
Software
Nikon ViewNX 2
System Requirements for PC Connection
Peripheral Devices
USB port, CD-ROM Drive
Eyepiece cover, battery charger, dust cap, body cap, lens cap, neck strap, USB cable, eyecup, shoe cap, audio / video cable
Battery Type
Nikon EN-EL14
Details
Battery Life Details
Photo shooting - 540 shots
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
6016 x 4000 , 4512 x 3000 , 3008 x 2000
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1920 x 1080 - 25 fps , H.264 - 1920 x 1080 - 24 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 1280 x 720 - 50 fps , H.264 - 640 x 424 - 30 fps , H.264 - 640 x 424 - 25 fps
12.5 cm
7.7 cm
9.6 cm
455 g
0 - 85% (non-condensing)
