Nikon D3100 DSLR - Bundle includes 18-55mm VR Lens, Case, Tripod & 8GB SD Card
Standard 1-3 working days
The camera that amazes
The Nikon D3100 digital SLR camera speaks to the growing ranks of enthusiastic D-SLR users and aspiring photographers by providing an easy-to-use and affordable entrance to the world of Nikon D-SLR's. The 14.2-megapixel D3100 has powerful features, such as the enhanced Guide Mode that makes it easy to unleash creative potential and capture memories with still images and full HD video. Like having a personal photo tutor at your fingertips, this unique feature provides a simple graphical interface on the camera's LCD that guides users by suggesting and/or adjusting camera settings to achieve the desired end result images. The D3100 is also the world's first D-SLR to introduce full time auto focus (AF) in Live View and D-Movie mode to effortlessly achieve the critical focus needed when shooting Full HD 1080p video.
Packed into the compact and lightweight body of the D3100 camera is a host of advanced Nikon technologies, such as the EXPEED 2 image processing engine. EXPEED 2 in conjunction with Nikon's 14.2-megapixel DX-format CMOS sensor is the driving force behind the enhanced performance and rich image quality. Ready to go wherever life leads, the D3100 features split-second shutter response and a blazing fast 11-point AF system to help ensure tack-sharp images. For shooting in challenging lighting conditions, ISO 3200 (expandable to 12,800) enables versatility in environments such as indoors or in the evening hours.
The stunningly simple-to-use D3100 is every family's answer to beautiful images. Whether the moment calls for a family portrait or a sharp shot of toddlers on the run, Guide Mode shows you how to capture stunning photos in no time at all. D-Movie lets you record full HD movie clips and capture the action in superb quality day or night. Nikon's advanced EXPEED 2 image processing engine maximizes the performance of the 14.2 megapixel CMOS sensor for amazingly clear images with vivid colors. Incredibly lightweight for an SLR, the D3100 makes it easy to capture your family looking wonderful wherever you go.
14.2 megapixel DX-format CMOS image sensor
Delivers lifelike images with vivid colors, reduced noise and smooth tonal gradations.
Provides enhanced movie recording, high-sensitivity performance and maximum image quality.
High ISO (100-3200) light sensitivity - extendable up to 12800:
Features an Auto ISO setting and is manually extendable up to ISO 12800 using the Hi2 setting. Enables faster shutter speeds, significantly reducing the risk of blurred images when you shoot fast-moving subjects or take pictures in low light.
GUIDE mode
Quick and easy-to-use in-camera assistance. Asks you about the picture you want to take and automatically optimizes settings for superior results. Sample images appear on the display to show you what will happen to your image if you apply the suggested settings.
D-Movie - full HD (1920 x 1080) movie clips
Record beautiful high-definition (HD) movie clips with sound. The camera's large image sensor and high ISO sensitivity offer exceptional image quality. NIKKOR lenses can be used to obtain cinematic effects and you can make simple edits of your clips in-camera by deleting scenes or saving specific frames as still images.
Live View with Scene Auto Selector
Makes it easy to compose images using the LCD monitor. Scene Auto Selector will select the best mode for the scene and subject you want to capture, and Fulltime servo AF (AF-F) mode keeps subjects in focus without the need to press the shutter release button.
Large 7.5 cm (3-inch), high-resolution LCD monitor
Makes it easy to view essential camera information, and a pleasure to review and edit your photos and movies.
Razor-sharp 11-point Autofocus system
Offers fast and precise autofocus coverage across the frame. Four AF-area modes, including 3D-tracking AF, deliver sharp results, whether your subject is off-center, moving fast or completely unpredictable.
Active D-Lighting
Automatically retains details in highlights and shadows for stunning images with natural contrast.
Picture Controls
Lets you set the look and mood of your images before you shoot. Choose from six settings: Standard, Vivid, Neutral, Monochrome, Portrait and Landscape.
Extensive in-camera editing functions
Let you edit and enhance images and movies in the camera. Offers techniques such as Red-Eye Correction and Quick Retouch, as well as a range of Filter Effects.
Dual Integrated dust reduction system
Image Sensor Cleaning and Airflow Control systems keep dust away from the camera's image sensor for clear, spot-free images.
Lightweight body and superior ergonomics
A secure grip makes the camera comfortable to handle. Dedicated controls for frequently used functions like Live View, D-Movie and shutter release make it a joy to operate.
Box Contents
- Nikon D3100 DSLR Camera
- 18-55VR lens
- Shoulder strap
- Body cap
- Hot shoe cover
- Eyepiece cover
- Battery
- Battery charger
- ViewNX2 all in one software package
- Quick Start Guide
- User Guide
- Warranty
- Camlink TP330 Table Top Tripod - Extends to 61cm, Spirit Level, 3 Way Tilt, Case
- Proper Bags Calypso MK II Digital SLR Camera System Bag - Black
Nikon D3100 - digital camera AF-S VR DX 18-55mm lens
Digital camera - SLR with Live View mode, movie recording
Lens Included
Memory Card Slot
SD card
Image Processor
Sensor Resolution
14.2 Megapixel
Max Video Resolution
1920 x 1080
Lens System
3 x zoom lens - 18 - 55 mm - f/3.5-5.6 G Nikon AF-S DX VR
Focus Adjustment
Automatic, manual
Min Focus Distance
28 cm
Image Stabiliser
Camera Flash
Pop-up flash
Optical - eye-level penta-dach mirror
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery ( included )
AV Interfaces
Composite video/audio, HDMI
Microsoft Certification
Compatible with Windows 7
12.4 cm x 7.5 cm x 9.6 cm
455 g
Lens Included
Sensor Resolution
14.2 Megapixel
Optical Sensor Type
Total Pixels
14,800,000 pixels
Effective Sensor Resolution
14,200,000 pixels
Optical Sensor Size
15.4 x 23.1mm
Field of View Crop Factor
Sensor Dust Reduction
Sensor Features
Air flow control system, Self Cleaning Sensor Unit
Optical Zoom
3 x
Image Processor
Image Stabiliser
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
Digital Video Format
Image Recording Format
1920 x 1080
AV Interfaces
Exposure & White Balance
Light Sensitivity
ISO 6400, ISO auto, ISO 100-3200, ISO 12800
Exposure Metering
Centre-weighted, spot, 3D colour matrix II
Exposure Metering Zones
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority, i-TTL program flash
Shooting Programs
Landscape, portrait mode, close-up, night portrait, Children, sports mode
Special Effects
Neutral, Vivid, monochrome, landscape, portrait
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, sunlight, Flash, shade
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/3 EV steps
X-sync Speed
Exposure Range
EV 0-20 ( ISO 100 )
Lens System
Focal Length Equivalent to 35mm Camera
27 - 82.5mm
Focus Adjustment
Automatic, manual
Min Focus Distance
28 cm
Max View Angle
76 degree(s)
Zoom Adjustment
Lens Construction
8 groups / 11 elements
Filter Size
52 mm
Lens System Mounting
Nikon F
Silent Wave Motor (SWM), aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation, wireless off-camera control
Additional Features
Continuous Shooting Speed
3 frames per second
Self Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
Direct print, USB 2.0 compatibility, DPOF support, display brightness control, digital image rotation, camera orientation detection, PictBridge support, histogram display, in-camera red-eye removal, cropping an image, GPS ready, LCD live view mode, face-priority AF function, highlight point display, Active D-Lighting technology, 1080p Full HD movie recording, face detection, built-in help guide, Scene Recognition System (SRS), Exif Print support, in-camera RAW processing, text input to Exif header
Viewfinder Type
Field Coverage
Dioptric Correction Range
-1.7 to +0.5
3" LCD display
230,000 pixels
Display Features
Microphone Operation Mode
Connector Type
1 x USB , 1 x HDMI output , 1 x composite video/audio output
Memory Card Slot
SD card
Nikon ViewNX 2
System Requirements for PC Connection
Peripheral Devices
USB port, CD-ROM Drive
Eyepiece cover, battery charger, dust cap, body cap, lens cap, neck strap, eyecup, shoe cap
Battery Type
Nikon EN-EL14
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
4608 x 3072 , 3456 x 2304 , 2304 x 1536
Video Capture
MOV - 1920 x 1080 - 24 fps , MOV - 1280 x 720 - 30 fps , MOV - 1280 x 720 - 25 fps , MOV - 1280 x 720 - 24 fps , MOV - 640 x 424 - 24 fps
12.4 cm
7.5 cm
9.6 cm
455 g
Scroll to top
