BT.com
Wishlist
Nikon Coolpix S30 Digital Camera - Black
Delivery
Standard Due date unavailable
The COOLPIX S30 is a camera designed for the family. It's water and shockproof so no worries. Capture your world with stills and movies.
Nikon Coolpix S30 - digital camera
Digital camera - compact
Memory Card Slot
SD card
Image Processor
EXPEED C2
Sensor Resolution
10.1 Megapixel
Max Video Resolution
1280 x 720
Lens System
3 x zoom lens - 4.1 - 12.3 mm - f/3.3-5.9
Focus Adjustment
Automatic
Min Focus Distance
30 cm
Digital Zoom
4 x
Image Stabiliser
Electronic
Camera Flash
Built-in flash
Display
LCD display - 2.7"
Supported Battery
2 x AA alkaline battery ( included ) , 2 x AA lithium battery ( optional ) , 2 x AA NiMH rechargeable battery ( optional )
AV Interfaces
Composite video/audio
Microsoft Certification
Compatible with Windows 7
10.2 cm x 3.9 cm x 6.5 cm
214 g
Enclosure Colour
Sensor Resolution
10.1 Megapixel
Optical Sensor Type
CCD
Total Pixels
10,440,000 pixels
Effective Sensor Resolution
10,100,000 pixels
Optical Sensor Size
1/3"
Optical Zoom
3 x
Digital Zoom
4 x
Image Processor
EXPEED C2
Image Stabiliser
Electronic
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF
Face Detection
Face-priority AF function, Smile Capture
Digital Video Format
AVI, MJPEG
Image Recording Format
JPEG
1280 x 720
AV Interfaces
Exposure & White Balance
Light Sensitivity
ISO auto (80-1600)
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Metering Zones
256
Exposure Modes
Programme, automatic
Shooting Programs
Close-up, food, fireworks, Underwater
Special Effects
Soft, Borders, fisheye, Diorama, Highlight, Selective Colour
White Balance
Automatic, presets
Max Shutter Speed
1/2000 sec
Min Shutter Speed
4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
29.1 - 87.3mm
Focus Adjustment
Automatic
Min Focus Distance
30 cm
Macro Focus Range
5cm
Zoom Adjustment
Motorised drive
Lens Construction
5 groups / 6 elements
Camera Flash
Camera Flash
Built-in flash
Effective Flash Range
0.3 m - 3.5 m : ISO auto ( wide lens ) , 0.5 m - 2 m : ISO auto ( tele lens )
Additional Features
Continuous Shooting Speed
1.5 frames per second for 4 frames
Self Timer Delay
10 sec
Additional Features
Audio recording, USB 2.0 compatibility, auto power save, DPOF support, display brightness control, digital image rotation, cropping an image, 720p HD movie recording, interval shooting mode, Exif Print support, Motion Detection Technology
Display
2.7" LCD display
Resolution
230,000 pixels
Display Features
Built-in
Connector Type
1 x Hi-Speed USB , 1 x composite video/audio output
Memory Card Slot
SD card
Software
Software
Nikon ViewNX 2
System Requirements for PC Connection
Peripheral Devices
USB port, CD-ROM Drive
Carrying strap, USB cable, cleaning brush
Protection
Waterproof, shockproof, dust resistant
Underwater Depth
Up to 3m
Battery Type
AA
Details
Battery Life Details
Photo shooting - 240 shots ( alkaline batteries ) , Photo shooting - 700 shots ( lithium batteries ) , Photo shooting - 410 shots ( NiMH batteries ) , Video recording - 0.8 hours ( alkaline batteries ) , Video recording - 3.8 hours ( lithium batteries ) , Video recording - 2.4 hours ( NiMH batteries )
Memory / Storage
RAM Installed
47 MB
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 3648 x 2736 , JPEG 2272 x 1704 , JPEG 1600 x 1200
Video Capture
AVI - 1280 x 720 - 30 fps , AVI - 640 x 480 - 30 fps
10.2 cm
3.9 cm
6.5 cm
214 g
0 - 85% (non-condensing)
Scroll to top
