BT.com
Wishlist
Nikon 1 J1 Mirrorless System Camera - 10mm Lens Kit - Black
Free delivery
Delivery
Standard Due date unavailable
For your very mobile lifestyle comes an imaging system with freedom to create and express as never before. Highly compact and portable, the Nikon 1 J1 goes everywhere you go. Moments from your amazing world are captured using a highly responsive autofocus and super fast shooting speed. In one touch you can work in Full HD (1080p) movie record mode. A camera so versatile you can even snap photos while recording movies. Unleash your creativity with Nikon 1 - offering a balance of high performance, advanced features, portability and an interchangeable lens system. Infuse your world with photos from every moment and connect as never before.
Busy lives filled with fleeting chances to record loved ones in action demand a camera that can keep up.
Designed to think fast and act even faster, the super-small Nikon 1 J1 interchangeable lens camera offers all you need to shoot great photos and movies.
Portable enough to take anywhere and easy to operate, it will bring new levels of speed, simplicity and enjoyment to the way you capture your world.
Nikon 1
An intelligent and ultra-portable camera system. Boasts a dedicated range of compact 1 NIKKOR interchangeable lenses. Crafted to bring new levels of speed, simplicity and enjoyment to the way you capture your world.
CX-format CMOS image sensor
Delivers the performance you need for stunning photos and movies. Offers the ideal balance between system size, speed, light sensitivity, resolution and depth-of-field. Enables beautifully detailed 10.1 megapixel images of even fast-moving subjects in any light.
Super high-speed autofocus system
Focuses so fast you can capture moments without delay. Boasts an amazing number of focus points for consistently sharp results. Instantly switches between Phase-Detection AF for shiny or moving subjects, and Contrast Detect AF if your subject is stationary, or poorly lit.
EXPEED 3 image processor
Engineered to deliver unparalleled levels of speed and performance in any situation. Equipped with two powerful engines that can process images at an incredible 600 megapixels a second. Offers superior noise reduction and enables the camera's groundbreaking shooting modes.
Blazingly fast continuous shot
Delivers full-resolution images at up to 60 frames per second, so practically no movement is too fast to capture. When you want to focus tightly on one subject - say a child or pet - the camera can track them and capture full-resolution images at 10 fps.
Motion Snapshot
Brings your stills to life in a click. Harnesses the camera's processing speed to simultaneously record a slow motion movie and a still image. As soon as you've taken your shot it instantly combines the two to create a `living image' and capture a moment in time as never before.
Smart Photo Selector
Always gets the best shot. Shoots 20 high-resolution images before and after you release the shutter, then saves your `best' five for you to choose from. Images are recommended based on facial expression, composition and focus.
Advanced movie recording
Lets you take a full-resolution photo while filming, without interrupting recording, and you can film in extreme slow motion for dramatic effect. Movies can be recorded in full HD and the Phase-detection autofocus system makes it easy to capture great action scenes.
Striking, minimalist camera design at its best
Boasts a strong yet lightweight body available in a range of colors. Packs a 7.5 cm (3-in.), 460k-dot LCD monitor with wide viewing angle and protective glass.
Intuitive operation
With clear menus, a minimum number of buttons, a built-in flash and an easy-to-reach mode dial for quick access to shooting modes. When you don't want to think about a thing, you can shoot in auto mode and let scene auto selector choose the best camera settings for you.
Built-in flash
Offers extra light when you need it. Handy for indoor shots or to soften images when the sun is behind your subject. Designed alongside the camera, it offers perfectly exposed results.
Expandable system
The family of 1 NIKKOR interchangeable lenses cover practically every type of scene, are all optimized for movie recording and boast a compact design for superior portability.
Mount Adapter FT1
Attaches to the camera's 1-mount to let you use any NIKKOR SLR lens. Trying out different lenses is a great way to experiment with how you shoot a scene, and if you use AF-S and AF-I NIKKOR lenses you can still make full use of the incredible Nikon 1 autofocus system.
Nikon 1 Short Movie Creator
Automatically creates short films from your photos and movies. Incredibly easy-to-use, it preserves the quality of every photo or frame of footage you shoot. Movies can be up to 30 minutes long and there is a range of styles to choose from.
Nikon 1 J1 - digital camera 1 NIKKOR 10mm lens
Digital camera - mirrorless system
Lens Included
1 NIKKOR 10mm lens
Memory Card Slot
SD card
Image Processor
EXPEED 3
Sensor Resolution
10.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens - 10 mm - f/2.8
Focus Adjustment
Automatic, manual
Min Focus Distance
20 cm
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery - 1020 mAh ( included )
AV Interfaces
HDMI
Microsoft Certification
Compatible with Windows 7
10.6 cm x 3 cm x 6.1 cm
234 g
Lens Included
1 NIKKOR 10mm lens
Enclosure Colour
Sensor Resolution
10.1 Megapixel
Optical Sensor Type
High Speed AF CMOS
Total Pixels
12,000,000 pixels
Effective Sensor Resolution
10,100,000 pixels
Optical Sensor Size
13.2 x 8.8mm
Field of View Crop Factor
2.7
Image Processor
EXPEED 3
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
135
AE/AF Control
Face-priority AF, Subject-tracking AF
Digital Video Format
H.264, MOV
Image Recording Format
JPEG, RAW + JPEG, NEF (RAW)
1920 x 1080
AV Interfaces
HDMI
Exposure & White Balance
Light Sensitivity
ISO 6400, ISO auto (100-400), ISO auto (100-800), ISO 100-3200, ISO auto (100-3200)
Exposure Metering
Centre-weighted, spot, matrix
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, close-up, night portrait
Special Effects
Neutral, Vivid, Custom Effect, monochrome, landscape, portrait
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, sunlight, Flash, shade
Max Shutter Speed
1/16000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±3 EV range, in 1/3 EV steps
X-sync Speed
1/60sec
Lens System
Focal Length Equivalent to 35mm Camera
27mm
Focus Adjustment
Automatic, manual
Min Focus Distance
20 cm
Max View Angle
77 degree(s)
Lens Construction
5 groups / 6 elements
Filter Size
40.5 mm
Lens System Mounting
Nikon 1
Rear focusing system, aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
5
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation
Additional Features
Continuous Shooting Speed
5 frames per second, 10 frames per second, 30 frames per second, 60 frames per second
Self Timer Delay
10 sec, 2sec, 5 sec
Additional Features
Audio recording, direct print, USB 2.0 compatibility, date/time stamp, DPOF support, display brightness control, digital image rotation, camera orientation detection, PictBridge support, histogram display, AE lock, AF lock, face-priority AF function, interval shooting mode, Active D-Lighting technology, 1080p Full HD movie recording, face detection, Exif Print support, Scene Auto Selector, Smart Photo Selector, Motion Snapshot
Display
3" LCD display
Resolution
460,000 pixels
Display Features
Built-in
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Sensitivity control
Connector Type
1 x Hi-Speed USB , 1 x HDMI output
Memory Card Slot
SD card
Software
Software
Drivers & Utilities, Nikon ViewNX 2, Nikon Short Movie Creator
System Requirements for PC Connection
Operating System Support
MS Windows XP SP3, MS Windows Vista SP2, MS Windows 7 SP1, Apple Mac OS X 10.5.8 - 10.6.7
Peripheral Devices
USB port, CD-ROM Drive
Carrying strap, battery charger, dust cap, body cap, lens cap, USB cable
Battery Type
Nikon EN-EL20
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 3872 x 2592 , JPEG 2896 x 1944 , JPEG 1936 x 1296
Video Capture
H.264 - 1920 x 1080 - 60 fps , H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 640 x 240 - 400 fps , H.264 - 320 x 120 - 1200 fps
10.6 cm
3 cm
6.1 cm
234 g
Scroll to top
