BT.com
Wishlist
NewStar Projector Ceiling Mount 72-112 cm Tilt/Rotate
NewStar Projector Ceiling Mount...
£88.84
4 in stock
£88.84
Add to wishlist
Delivery
Standard 3-5 working days
The NewStar BEAMER-C350BLACK is a universal beamer/projector ceiling mount. By using this mount you can easily tilt, rotate and swivel the beamer/projector. The product can be used with every beamer. The cage-construction makes it possible to also attach beamers without a hole pattern. The distance from the ceiling to the beamer is 72 - 112 cm. This model fits virtually every projector weighing up to 12 kg. This product is a complete ceiling solution that includes all possible installation material.
NewStar Universal Projector Ceiling Mount, Height Adjustable (72-112cm) - Black - ceiling mount
Ceiling mount
Adjustable Height
72-112 cm
Tilt
Recommended Use
Projector
Max Load Weight
12 kg
5 years warranty
Adjustable Height
72-112 cm
AV Furniture
Ceiling mount
Mounting Components
Ceiling mount
Recommended Use
Projector
Tilt
Max Load Weight
12 kg
Adjustable height, rotating, swivel adjustment
Limited warranty - 5 years
Scroll to top
