BT.com
Wishlist
NewStar Mobile Flatscreen Floor Stand/Trolley 32-70"
NewStar Mobile Flatscreen Floor...
£620.91
£620.91
Add to wishlist
Delivery
Standard 1-3 working days
The NewStar PLASMA-M2000E is a mobile floor stand for LCD/Plasma flatscreens up to 70" (175 cm). With this product on wheels you have perfect flexibility to place the flatscreen where ever you want. A shelf for a notebook or DVD player is included. The height can be adjustment between 115-185 cm. Cables can be placed in the column. Suited for flatscreens between 32-70" with a maximum weight of 125 kg and a maximum VESA hole pattern of 870x620 mm. Perfect for exhibitions, presentation rooms, class rooms and hospital!
NewStar PLASMA-M2000E - cart
Cart
79.2 cm x 79.6 cm
Adjustable Height
115-185 cm
Tilt
15°
Lift
115 - 185 cm
Recommended Use
LCD display
Recommended Display Size
37"-85"
Flat Panel Mount Interface
From 200 x 200 mm, up to 870 x 620 mm
Max Load Weight
125 kg
5 years warranty
79.2 cm
79.6 cm
Adjustable Height
115-185 cm
AV Furniture
Cart
Recommended Use
LCD display
Cable Management
Integrated cable management
37"-85"
Tilt
15°
Lift
115 - 185 cm
Adjustments
Height, tilt
Max Load Weight
125 kg
VESA mount adjustable height (115 - 185 cm)
Limited warranty - 5 years
Scroll to top
