BT.com
Wishlist
NewStar Mobile Flatscreen Floor Stand 27-60" 1 screen
NewStar Mobile Flatscreen Floor...
£441.55
Hurry, only 2 left in stock!
£441.55
Add to wishlist
Delivery
Standard 1-3 working days
The NewStar PLASMA-M1800E is a mobile floor stand for LCD/Plasma flatscreens up to 60" (150 cm). With this product on wheels you have perfect flexibility to place the flatscreen where ever you want. A shelf for a notebook or DVD player is included. The height can be adjustment between 110-180 cm. Cables can be placed in the column. Suited for flatscreens between 27-60" with a maximum weight of 50 kg and a maximum VESA hole pattern of 600x450 mm. Perfect for exhibitions, presentation rooms, class rooms and hospital!
NewStar Mobile Monitor/TV Floor Stand for 27-70" screen, Height Adjustable - Silver - stand
Stand - floor-standing
Adjustable Height
110-180 cm
Tilt
Recommended Use
Plasma panel
Recommended Display Size
27"-60"
Flat Panel Mount Interface
Max Load Weight
50 kg
Silver
5 years warranty
Adjustable Height
110-180 cm
Silver
AV Furniture
Stand
Recommended Use
Plasma panel
Placing / Mounting
Floor-standing
Shelf Qty
1
27"-60"
Tilt
Max Load Weight
50 kg
Adjustable height, wheels
Limited warranty - 5 years
Scroll to top
